cgguy09
1971 CB350 K3
Hey Guys,
I had a thread on this forum earlier, but it was too many problems for one thread so I'm piecemealing it out.
The Dummy Signal Light will not light up when the signals are engaged . The Signal Light will light up when Left Signal (Orange Wire) is engaged and grounded but when I put on the right signal (Baby Blue wire) and try to ground it, it starts sparking & blows the fuse.
I removed the wire set from the frame and tested it again independently I got the same results...Then when the Blue Wire was Live instead of grounding the bulb, I grounded the orange wire & it was perfect.
I assume the Orange and Blue wires take turns on which is positive and which is the ground depending on the signal switch, but maybe that's wrong.
Any insight or ideas about this?
