Over the past week I've been looking into the blower drive take off that I was contemplating - ie from the alternator fixing bolt [ 12mm ]. It's the only logical / practical place, but I was concerned about the torsional shear stress on the fixing. The blower will take around 15 - 20 bhp to drive, but it's the inertia that needs to be overcome that's a concern. Soooooooooo - back to the turbo then !!! What's that about " I used to be indecisive - now I'm not so sure" !!
The blower set up is much more familiar to me, but I do not want to take the risk of a marginal drive output. So I will revert to using he same take off to drive the Gixer oil pump for the oil cooler and turbo feed. The only good news [ ? ] is that I spent some months thinking about the turbo set up and planning the packaging. One of the major benefits is the much lower weight and compactness.
The decision was finally declared a no-brainer when our pal Der-Nanno informed me that he's found a carbon seal turbo for his TR1 project. Thanx mate ! That means I can use the SU carb I have in a draw through set-up and I already bought most of the ancillaries I will need - boost gauge, oil pressure gauge, oil lines and fittings, etc., etc. That makes the whole packaging much simpler - including manifolding, even my 2 > 1 high level exhaust will easily hook up to the turbo flange !
The ramp and all parts are now round at my pal's garage, he's just finishing replacing and moving some of the light fittings and then we're good to go.
