Liam's ACE 125
Getting into the new speedo mount and moving the ignition.
Original
After a little while in the shed the new one.
Here is how the instruments were this morning.
Here is the new bracket test fitted before I solder the LED's in
The drivers eye view
Hi Liam
Was it hard to remove the grips on both ends of the original handle bar, to relocate to the clip-on's ? I wanted to also fit clip on's, or maybe change the stock handlebar to a set of Jota's, but am not sure how to remove the grips, throttle, etc.
With your speedo tidy up, did you consider installing a tacho also ?
Thnks,
Haz
Hazza00 said:
Hi Liam
Thnks,
Haz
Hi Haz,
i use WD40 with the straw, shove it under the grip and give it a squirt then work the grip off and use hairspray to slide them back on then it sets into place.
... thanks Liam !
(hope the Minister of War & Finance won't object to me using her hairspray ! hehe)
Haz
Hazza00 said:
... thanks Liam !
Haz
If she does, use a window cleaner, that works fine too ;-)
I think she has started to loosen up, hit 100 on the way to work with the standard gearing.
I will be doing the valves and an oil change this weekend try and keep things tip top.
Valve adjustment this morning.
Skyteam cover off,
Rocker cover off,
Screw cap thing removed and T lined up,
Valves adjusted to 0.05mm turned over and checked again perfect tried to get a 0.07mm gauge in the gap didn't go so happy the gap is actually 0.05.
While the skyteam cover was off I thought I would off the logo,
Nearly there with a bastard cut.
Cleaned up with a 2nd cut,
Them some wet sanding with 1000 grit,
A quick polish with auto sol and it's back on!
Now for a ride to get her warm and drop the oil.
