Sort of sure
Used to think it was EGR as it seemed hard to get air into a high pressure area ( the exhaust) but quite a few of these systems are not even plugged into the airbox anymore so its not EGR .
Wiki quote "Aspirated air injection
Air injection can also be achieved by taking advantage of the negative pressure pulses in the exhaust system at engine idle. A sensitive reed valve assembly called the aspirator valve is placed in the air injection plumbing, which draws its air directly from the clean side of the air filter. During engine idle, brief but periodic negative pressure pulses in the exhaust system draw air through the aspirator valve and into the exhaust stream at the catalytic converter. This system is still used on modern motorcycle engines, e.g. the Yamaha AIS (Air Injection System)."
