回覆: New Carb
thanks eveyone, it is very helpful tips.
i have not changed, adjusted the throttle cable at all, it is still the stock, will it matters if the length is not perfectly right bcos the new VM22 seemed a bit deeper/taller than the stock one?
Will check the slide facing the right way too, but im sure it is as i have assembled it a several times before it went in just to be sure i knew how to.
But what i have noticed after the new carb setup is the carb position is being slightly taller where the top of the carb (the connection of the black rubber together with throttle cable) is touching the frame of the bike, and i have to force the air box connection to go around the air intake of the carb. Not sure if anyone using VM22 have the same issue ?
cheers
Sent from my IM-A880S using Tapatalk
