Tune-A-Fish
BOTM LOSER Proudly Deplorable
Do you have power washers in OZ a goo douche would go a ways to keep dirt outa that motor while it's open.
Tune-A-Fish said:Do you have power washers in OZ a goo douche would go a ways to keep dirt outa that motor while it's open.
xb33bsa said:a condensor for an xr75 will work fine no reason to mount it to the coil.just mount it up there where it dont get rubbed or vibrated on
Tune-A-Fish said:Is it just me or like toilets these OZY bikes have the throttle AND kick start on the left??
https://www.youtube.com/watch?v=Hb2inWprGMM&feature=youtu.be
catsy said:haha filmed on laptop so does the whole flip reverse thingo
A shame about the kickstarter shaft. That, my friend is exactly the issue that has caused their rareness. I'm not totally sure what causes it. Whether people don't get it all the way on or if it loosens easily. The lever is different for the later years, which maybe was a design improvement. I was fortunate to find a 1978 parts bike for $100. I would look that route as well. Strangely, you can often find complete parts bikes cheaper than guys want just for the shaft. I didn't dig around a lot because I found mine quickly, but apparently some guys were somehow mating a kawasaki shaft to the broken off XL shaft. Not exactly sure how or which one, but it might be worth searching.catsy said:AND of course i didnt notice because its kicked over and was in place, but the kickstarter is bardly bent and on its way out clearly, i cant remove the RHS case because of it so ive fixed the oil leak with a new gasket on the LHS but have had to leave it as is until i can source a new shaft which are few and far between. im also considering a engine swap.
xb33bsa said:get some new sidecase cover gaskets and seals you gotta pull off the clutch cover anyway to clean out the filter trap
pull of both covers then warm it up and rise it out
