TR1 wannabefast&light
Got my GPS speedo installed, had to test the 0-100kmh and 1/4mile times.
Very pleased to get under 13s already on the 2nd run.
0-100kmh times pretty solidly spot on 4,0s, best time so far 3,77sec.
Got some fresh rubber.
Avon 3d X-M 70 profile rear nicely adds a few cm's to the radius hence reducing the RPMs to 4k at 100km/h (previus tire was 60 profile michelin piolot and somehow flat on top)
Front is Avons 3d ultra
It always amazes how much new tires improve the handling, cornering is now really smooth and "confident"
Went to local bikeshop to do a dyno run, they politely pointed vacuum leaks in the intake manifold "joints" that I tried to plug with duct tape or "Jezus tape" as we call it in Finland, well Jezus does not work, or it does for 30 mins or so but then the glue gives up and it leaks, did a quick fix and plugged the intake holes with brake caliper rubber plugs and no more vacuum leaks.
After the fix the Air/fuel ratio was almost spot on around 13,2 all through the rpm range which was pretty amazing.
Had to do a 0-100km/h test, new record! yippikaiyee mf.
