www.Moto-Madness.com
Author Topic: 74 Honda XL 350 - The Turd  (Read 35789 times)
Offline trek97
Re: 74 Honda XL 350 - The Turd
« Reply #460 on: May 23, 2017, 18:38:03 »
When static timing, points "open" at F mark correct?
May or may not be a silly question to ask.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #461 on: May 23, 2017, 18:49:16 »
Yup.
Offline trek97
« Reply #462 on: May 23, 2017, 18:58:57 »
Yup.
Ok just had to ask.  Ya know.  ::)
Online irk miller
« Reply #463 on: May 23, 2017, 19:02:27 »
You're not answering my questions.  :-\  At what RPM are you setting your idle with a gun?  Is there preload on your advancer springs at idle or at rest? If you're springs are stretched, which happens when they get old, you can lose up to 10 degrees or so of advance, which is 1/3 of your total advance.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #464 on: May 23, 2017, 19:02:54 »
So, with the timing light on and bike idling, this is where the points plate is when the F mark lines up with the index mark.
For reference, when I set static timing the hash mark on the points plate was pretty close to lining up with the mark on the head.
« Last Edit: May 23, 2017, 19:06:01 by advCo »
Online irk miller
« Reply #465 on: May 23, 2017, 19:03:41 »
That's retarded not advanced.  As you move toward the timing mark (right) you're advancing it.
Offline trek97
« Reply #466 on: May 23, 2017, 19:06:04 »
Gap is spec?
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #467 on: May 23, 2017, 19:07:32 »
Right. If I said advanced that's my bad, it's retarded. I'm setting idle timing @ 1200 RPM.
Offline trek97
« Reply #468 on: May 23, 2017, 19:08:49 »
Re-check static. Advancer is mechanically locked to the cam w a pin or key or something?  So, it cant slip on cam.
Online irk miller
« Reply #469 on: May 23, 2017, 19:10:58 »
That's way too retarded on the timing.  If anything, you should be slightly on the other side of the mark.
