Author Topic: 74 Honda XL 350 - The Turd  (Read 49569 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Re: 74 Honda XL 350 - The Turd
« Reply #470 on: May 23, 2017, 19:25:55 »
Re-check static. Advancer is mechanically locked to the cam w a pin or key or something?  So, it cant slip on cam.
Yep the points plate and advancer is almost identical to my 360 just with one less point. Gap is smack in the middle of spec.
I know its too retarded. But that is what the timing light is telling me. Which is why I think that something's up.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #471 on: May 23, 2017, 19:29:47 »
The advance setting on the timing light should be at Zero, yes?
Offline irk miller
« Reply #472 on: May 23, 2017, 19:35:49 »
Check your advancer springs.  There should be pre-load on them.  If they're stretched, you're losing advance and thus bogging and losing power.  It can also cause hard starts and rough idle.
Offline trek97
« Reply #473 on: May 23, 2017, 20:08:01 »
Sorry I cant answer this.  My timing light doesnt have that feature.  Its older than you are.
Offline Hurco550
« Reply #474 on: May 23, 2017, 20:38:30 »
forget all this "ignition" crap, cut your losses and drop a diesel klr lump in it and call it done.
your welcome
~ bradj
Offline irk miller
« Reply #475 on: May 23, 2017, 21:21:48 »
Convert it to electronic ignition.
Offline JSJamboree
  • DTT BIKE OF 2016
  • Weird Indy Kid
« Reply #476 on: May 24, 2017, 01:07:02 »
Buy an old two stroke so you just don't deal with timing chains, valves, or advancers.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #477 on: May 24, 2017, 09:29:44 »
I'm thinking this may be where my problem lies. I'll pull the advancer out of the parts motor bin and compare.
If I grab the advancer lobe on the cam with my fingers and try to rotate it there is some slop there.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #478 on: Jun 02, 2017, 15:59:48 »
There's not enough tension from the springs. I don't think they're sold as an individual part, though.
I took the advancer off the parts motor, it's a different design with different springs. Seized, going to rebuild and try swapping it on.
Offline irk miller
« Reply #479 on: Jun 02, 2017, 16:55:27 »
I've gotten away with removing a coil- basically cutting off the pigtail and pulling one coil to become the pigtail to replace it.
