74 Honda XL 350 - The Turd
Nice pegs, is that the stock shift lever? Mine is all messed up, was looking for an aftermarket one with similar bend. Got any ideas? Probably a moose one or the likes.
Stock shifter. There are some used ones available on eBay. Looks like most of the moose/aftermarket ones are for the mid 80s XL250/350
Last load of parts coming in. Big thanks to Mr. E for spinning me up some sweet brass tach/speedo plugs and the missing link for the rear brakes.
An XL seat pan with a crappy cover and o-ring chain from eBay, and air cleaner unit from cxman.
Will be buttoning some things up this weekend for sure. Just waiting on some mandrel bends and exhaust parts and she'll be running.
yours is prettier
but mine is running i have a vm36 mikuni on it and it pulls real nice i just have a minor nuisance oil leak on the left cover to deal with
its dripping on to the exhaust
but after 18 years in boxes it runs again
cxman said:
yours is prettier
Sweet! I'm interested in doing the VM36 swap down the road, I will be in touch for sure.
Those left covers are a pain in the ass, I went through 2 junk ones before I found a good one
Brass kicks ass... I once got a little box from Mr. E... I keep my private jets init
cxman said:
must be a big box most private jets i have flown are pretty big
Only ever flown private "jet" twice... My "private jets" are factory fuel distribution ports :-[
Tackled the header and muffler situation this weekend. Kamn spun me up a header spigot to start off with (thank you sir). Shortened up the inlet on the YZ muffler, I couldn't use the FMF it was just too beat up. Tacked everything up, reconfigured the section behind the footpeg about 10 times, and then sealed everything up.
Made a new hanger with some 3/16" rod and 1/8" steel.
Had to keep the muffler low since I'm going to be fitting boxes. May have to relocate the top support later.
The pipe behind the footpeg clears my boot with a couple inches to spare, but ill probably be moving around a bit on the pegs so I decided to throw together a mini heat shield to protect my boot just in case.
I had a piece of aluminum lying around from another project. Drilled some speed holes, shaped it, and then welded a couple of tabs with nuts welded underneath to the header. Should do the trick.
trek97 said:
Looks cool. A bit surprised you didnt go w a high pipe, though.
I thought about it. The 350 originally comes with a low header and upswept muffler, so I decided to keep the stock position for the header and mount the muffler lower. Next step is to build a luggage carrier off the back and some pannier mounts - I am going to run a 40mm ammo can on each side for panniers, and I think the high pipe would've been a pain to lash up with the boxes.
irk said:
I think I have one of your side covers, if you don't already own them.
Thanks. I have them, they're sitting in my office waiting for me to decide what graphics to put on them. ;D
i need a package rack for mine but this is a little rude
http://www.ebay.com/itm/NOS-Honda-XL-600-R-XL-350-R-XL-250-R-New-Rear-Luggage-Rack-Assembly-1983-1987-/191753525109?hash=item2ca5669775:g:Q3YAAOSwo6lWMQfo&vxp=mtr
