E
EricTresch
Guest
Please Delete Account.
EricTresch said:"cherry CB360"
"wasn't running"
"It looks to be in great condition"
"recommend any different direction I could go"
trek97 said:make it run and ride it
deviant said:Don't worry about the starter and center stand if you're really making it a dirt ride. Both are weight and the center stand takes up clearance.
trek97 said:Let me clarify. You dont have to ride w the center stand intact and on the bike. Sure, remove it. Just dont cut the mounts off. That way you can keep the stand on the shelf and easily quickly simply slip it on and off when need be. I just keep a 5/8x7 inch bolt w it on the shelf.
Personally, I'm looking at a PD conversion with an accelerator pump to compare with a 28mm Mikuni on mine. But, the 28mm Mikuni is known to work very well on a CB360.redwillissuperman said:Since Mikuni conversions are on my mind, here is my two cents:
... 28mm round slide Mikuni carbs or "flat slides" ... should work but never seem to.
EricTresch said:2. Suspension. I was originally intent on keeping the stock front end but after chatting with PJ I am leaning toward an entire Katana swap with GSX-R internals. Keeping the stock hub. Or should I stick to the stock stuff and rebuild. Add a brace. Billet Top and bottom?
ridesolo said:The EX500 Ninja (and EX250) forks are pretty much a bolt-on using the bearing set from AllBalls. They're 37mm, so more hefty than the stocker 33mm legs. You pretty much need to have a billet top triple, though, though the Kawi top and bars could work. I believe somebody on here found a disc that would bolt to the 360 front hub so you could use the EX caliper and mount. EX stuff might be easier to find and cheaper than Katana stuff, not sure.
That would be me. You have to remove the rivets to separate the centers and either cut down or find shorter caliper bolts, plus ream the rivet holes to 8mm from 6mm. I wish I would've known about the EX fork swap. It would've made my deal a bit easier. I went with a CB750 front end, which is also pretty much bolt on, but I'll have to custom fab caliper mounts.ridesolo said:The EX500 Ninja (and EX250) forks are pretty much a bolt-on using the bearing set from AllBalls. They're 37mm, so more hefty than the stocker 33mm legs. You pretty much need to have a billet top triple, though, though the Kawi top and bars could work. I believe somebody on here found a disc that would bolt to the 360 front hub so you could use the EX caliper and mount. EX stuff might be easier to find and cheaper than Katana stuff, not sure.
Mr.E said:Hey good idea. those forks are nice and standard/long. not a low sport stance
Mr.E said:On the suspension: this is just me speculating from a barstool in my shop, but something about the katana fork/gsxr doesnt jive.
crazypj said:I got some 250 Ninja forks off e-bay. (not one of my smartest purchases : )
Top yoke is ugly as F***
Not an easy swap in my opinion, stem is wrong diameter to be easily changed although (All Balls didn't have a conversion kit when I got them)
It's just too expensive for the parts needed (new top yoke )
I may make them work someday, just not today ;D
Accelerator pump carbs will be a real good idea for street riding, as long as delivery can be set (or it gets too rich)deviant said:Personally, I'm looking at a PD conversion with an accelerator pump to compare with a 28mm Mikuni on mine. But, the 28mm Mikuni is known to work very well on a CB360.
ridesolo said:Admittedly a new, custom top yoke is easier to afford when your brother is your designer/machinist.
