Author Topic: Ricks Rect/Reg, 5oHm coils & Munit Blue  (Read 792 times)
Offline CB550F
« on: Nov 21, 2017, 03:38:18 »
Hoping I can get some advise on wiring the following units to my Honda '76 CB550F.
- Motogadget Munit Blue
- Ricks Rectifier/Regulator
3 yellow wires
green wire
red wire
black wire
green wire
white wire
- 5 Ohm Coils
black wire (each coil)
yellow wire (each coil)
- Bike Alternator
3 yellow wires
green wire
white wire
- Bike points cover end
yellow wire
blue wire
black wire
Thanks
Online trek97
Re: Ricks Rect/Reg, 5oHm coils & Munit Blue
« Reply #1 on: Nov 21, 2017, 06:23:17 »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #2 on: Nov 21, 2017, 14:27:59 »
If you have any specific questions we can definitely help. For more general stuff, see trek's posted diagram. The colors should match up (more or less).
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline CB550F
« Reply #3 on: Nov 24, 2017, 02:01:00 »
Thanks. I made a quick diagram, can you advise if the wiring is correct?
Also, I'm not sure about the black wires on each coil and the 'accessory' terminal on my key ignition (see below).
Online trek97
« Reply #4 on: Nov 24, 2017, 07:50:05 »
The two coil Blacks are switched +12vdc feeds controlled via the kill switch.  "Black w white trace, on schematic" (With key switch on and Kill switch in run position +12vdc is fed to coils, in kill positions +12vdc is cut off to the coils = killing the engine). That way you can kill the engine via Kill OR Key switches.
As far as the M unit.  I have no experience w that.  Looks like it adds confusion to a pretty simple system.
As far as your drawing is concerned I question the two wires from the M unit "Start" terminals spliced together and feeding +12vdc to the starter solenoid???  Doesn't really seem right.  As the start switch, bar controls has to be involved in the circuit somewhere.
And the key switch "accessories" appears as though it would be the "parking" position (brown & brown/white) on the key switch (feeding +12vdc power to tail, parking and gauge lights" only.
But like I said, I don't know M unit.  Sorry I can't help more w that.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #5 on: Nov 24, 2017, 22:24:08 »
Also, no fuse for the wire heading from the battery to the solenoid. It pulls too much current to be fused. That connection should be direct to battery.
Offline CB550F
« Reply #6 on: Nov 25, 2017, 00:19:06 »
Thanks guys. Below is an updated diagram with a few changes.
- Black wire from each coil has been directed to the 'ignition' terminal on the m-unit blue.
- The starter solenoid goes straight to battery.
- Rectifier/Regulator goes straight to battery.
- The black wire on the rectifier/regulator goes to the 'ignition' terminal on my key switch.
Is this alright?
Also, will I need to add a relay to the key switch? If so how do i go about doing this?
Appreciate the help.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #7 on: Nov 25, 2017, 00:26:22 »
No relay necessary on the ignition switch, but I would put a fuse on the red wire. 1A is good. Then move the black wire from the R/R over to the AUX port on the m-unit and off of the switch. The ignition switch should only go to the LOCK input.
Offline CB550F
« Reply #8 on: Nov 25, 2017, 00:31:35 »
Would the 'aux' be 'ignition' on the blue version? I believe the previous version had 'aux' but blue doesn't.
