Author Topic: Starting problem  (Read 1386 times)
Offline r4g5
Starting problem
« on: Dec 08, 2017, 04:37:49 »
Hi, had a weird problem yesterday when I was leaving work.
Left the bike in gear cos I couldn't get into neutral on the while coasting to a stop. Finished work and hopped on turned the key and hit the ignition switch. Got a laboured turn over like she had a flat battery but then all the electrics went out (no light, indicators, ignition). First thought was that I had blown the fuse. In the process of checking it i rocked the bike and tried it again and it tried to turn over again...so rocked her some more and she fired up and electrics were all good.
I rewired the ignition but I soldered and covered the connection so I think the connections are all good, will recheck them. It's the rocking that got me. Used to do it on old cars with a flat spot on the flywheel to get them going, but they would still crank. I'm wondering if it could be a stator problem?
Since then I've used the bike and she started and ran no problem, what do you guys think? She's running and starting fine at the moment I'm just a bit scared if the problem is symptomatic of something on the way out or it gets worse...cheers
Offline The Mariner
  • Adelaide, Australia
Re: Starting problem
« Reply #1 on: Dec 08, 2017, 06:35:58 »
Are you sure it's electrical ? If you couldn't find neutral it sounds more like a clutch or gearbox issue... especially if rocking the bike fixed it. Maybe the clutch plates are stuck (or not disengaging fully) and rocking the bike in gear broke them free ?
Regards,
Phil.
ACE 125, BMW F800R, 1972 Suzuki GP125 Retirement project.
Offline SONIC.
« Reply #2 on: Dec 08, 2017, 09:31:42 »
Sounds like a dead battery to me?
Barely turning it over, then it goes dead. Then you wait a minute and it fires up on the batteries last leg. Once it's running the charging system takes over.
Offline orrible-64
Starting problem
« Reply #3 on: Dec 08, 2017, 17:49:29 »
Check ground lead to motor ( sprocket cover). May be loose.
Offline stroker crazy
  • crazy as a fox
« Reply #4 on: Dec 08, 2017, 20:33:04 »
That seems to be a relatively common thing, it happened on my bike.
Crazy
“Ride like the Wind” W.H.
Offline eraser
« Reply #5 on: Dec 09, 2017, 01:32:46 »
Yeah sounds like loose battery terminals or something similar. IMO
Offline r4g5
« Reply #6 on: Dec 09, 2017, 16:01:23 »
Cheers for the comments guys...think there are a few wee problems with the beastie, part of the beauty 😀 I'll check the grounds, have just got new connectors and switches/LEDs and planned on rewiring most of it so with be sure to check all the grounds and this sounds most likely.
Mariner, neutral is a complete pig to find and normally if I can't find it while coasting I just give up cos I don't want to seem like an idiot for 5 minutes before getting off the bike 😂
About 1100km now so hopefully still needs some running in to loosen up a bit?
On a side note, the petrol cap I fitted doesn't help with the fuel leakage so I'm going to try and get some cork and hopefully seal it better...tried various rubber gaskets but they were either too thick or too thin.
Thanks again for the help, happy riding
Paul
Sent from my ONEPLUS A5000 using DO THE TON mobile app
Offline Paul in adelaide
« Reply #7 on: Dec 09, 2017, 19:05:24 »
Finding neutral only seems to happen for me going down from second ? ..     I have given up on trying from first ,
Offline eraser
« Reply #8 on: Dec 10, 2017, 03:27:42 »
Even the 50 doesn't like neutral from first, light comes on but shes not in neutral (most of the time), found that out after parking, releasing clutch and falling over with the bike ;)
Offline r4g5
« Reply #9 on: Dec 10, 2017, 03:41:22 »
When I want neutral from first I got a snowball chance in hell, accelerating away from the lights on the other hand...😀
