Author Topic: sky team weak.....  (Read 777 times)
Offline xanoju
sky team weak.....
« on: Dec 11, 2017, 09:31:52 »
i bought a skyteam ace 50, but i canīt climb any street... is it normal ? i live in brisbane, and i dont meet no one to fix it, orr to put a upgrade .....
Offline Brodie
  • Gold Coast, Queensland
Re: sky team weak.....
« Reply #1 on: Dec 12, 2017, 03:23:35 »
It is a 50cc bike. The power that the engine would put out would be having a hard time moving the frame along let alone a rider on top.
Buy a larger engine for it if you want a real power boost. I have seen engines as larger as 300cc that fit into that chassis.
Offline The Mariner
  • Adelaide, Australia
« Reply #2 on: Dec 12, 2017, 06:12:44 »
Howdy,
Try 'The Cafe Racer Shop',
Shop 5 , 30 Shore Street (West), Ormiston, 4160. Queensland.
ph. 0427 223 723
Regards,
Phil.
ACE 125, BMW F800R, 1972 Suzuki GP125 Retirement project.
Offline eraser
« Reply #3 on: Dec 13, 2017, 08:02:46 »
Yep I visited the cafe racer shop, very knowledgeable.
However I just drove across Brisbane... 4 times.. and it was a 50cc Ace, and I initially had issues understanding you need to feather the clutch in first when you start on a hill, otherwise it will get bogged down and cut out, even stopping at lights just ride the clutch a little until you get going, don't just drop it, but she should happily climb a hill at about 15-25ish kph in first(down from neutral) and sometimes you might get it to second if its not too steep.
Offline Paul in adelaide
« Reply #4 on: Dec 14, 2017, 23:17:28 »
there is a restrictor in the inlet manifold .      take off the carby and manifold , then remove the restrictor from the inlet .
also the hose that goes to the manifold can also be blocked off ,  remove it and put a piece of tape over the tube    / fitting  coming out of the manifold and then put the hose back on  .
It will still be slow but we have to start somewhere .
« Last Edit: Dec 15, 2017, 07:33:38 by Paul in adelaide »
