www.Moto-Madness.com
Author Topic: cl360 Pamco installation / kill switch question  (Read 830 times)
Offline millermatic187
Re: cl360 Pamco installation / kill switch question
« Reply #10 on: Dec 14, 2017, 16:34:06 »
Hey Miller- Thanks for the reply.  I wired the red wire to the black/white wire from the kill switch per this diagram from the Pamco website (cb360ignition.com).  Are you saying I should take the red wire from the Pamco unit and disconnect it from the black/white wire from the coils, then reattach it to the ignition switch (where I put my key)?  Sorry if I sound basic, I'm still new to wiring.  Thanks for your help, I really appreciate it.
Doesn’t matter, as long as it’s getting 12v from a switched source.
Offline hillset
« Reply #11 on: Dec 15, 2017, 14:36:48 »
Hey Sonrier and Miller- I've been trying for the past day to get the bike to start and I'm still having trouble.  Checked compression and fuel to the carbs, taken both carbs off and cleaned them, and replaced the spark plugs, but I'm still not getting ignition.  I've also pulled both spark plugs and visually confirmed I'm getting a blue spark visible in daylight on both plugs.  The engine is turning over, but won't start to idle.
I was checking my coils today and I'm wondering if one of the secondary windings is bad.  Here is what I got when I tested my coils:
Red lead from multimeter to yellow lead from coil, black lead from multimeter to black/white wire from coils: 4.5 ohm
Red lead from multimeter to blue lead from coil, black lead from multimeter to black/white wire from coils: 4.5 ohm
Red lead from multimeter to right spark plug cap, black lead from multimeter to black/white wire from coils: 18k ohm
Red lead from multimeter to left spark plug cap, black lead from multimeter to black/white wire from coils: no reading (multimeter says OL)
So from what I've read, this seems like the secondary winding on the left coil has failed.  Is this correct?  Is there something else I can check before I order new coils?
If I need to order new coils, is there a brand that is recommended?  If not, I was planning on using the coils from common motor collective.
Also, could a failed secondary winding on one coil prevent the bike from starting?  It seems like if I'm getting a blue spark in both spark plugs thats visible in daylight, that should be sufficient to ignite any fuel thats getting into the cylinder, but I could be wrong.
Just for giggles I swapped the blue and yellow wires per your recommendation Sonreir, and the bike kept backfiring so I switched them back.  I feel confident the Pamco unit is wired up correctly, I'm just not getting ignition of fuel.  Thanks for your help, I really appreciate it.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #12 on: Dec 15, 2017, 14:42:49 »
If you're getting spark, the problem isn't likely to be with the coils. And if you've checked compression and the numbers are good, that leaves only a couple of possibilities.
1.) Your spark is not timed correctly. Double check timing.
2.) You're not getting enough fuel. After attempting to start the bike, are the spark plugs wet? A dozen kicks or so should make the insides of the cylinders very wet with fuel. It will be noticeable. If they're not wet, try pulling the plugs and spraying ether into the cylinders before sealing everything back up. If you get a couple of putters then you know the fueling is a problem.
3.) You're not getting enough air. It's possible to dial out the idle so much that the butterflies in the carbs close completely and do not allow enough air to enter the cylinders. Crack the throttle a hair when trying to start the bike and see if that changes things.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline hillset
« Reply #13 on: Dec 15, 2017, 14:59:56 »
Sonreir, thank you so much for the quick reply.  I was concerned about timing but I'm not sure how to test timing on a Pamco unit without getting the bike to idle.  The timing instructions on the cb360ignition.com website refer to timing at idle, but I'm not able to get to idle yet.  How should I check for timing without being able to idle the bike?
I also checked the plugs to see if they were getting fuel into the cylinder after I did the compression test.  The right plug was wet and smelled of fuel, the left plug was less wet and didn't smell as strongly.  I believe there is fuel getting into the left cylinder, just not as much as there should be.  When you say "spray ether into the cylinders before sealing everything back up", do you mean take the carbs off and spray ether into the cylinders?  For someone who doesn't have ether sitting around at home, is there another substitute?
I checked the butterfly valves in the carbs when i took them off to make sure they were getting some air with the throttle closed.  The idle adjustment screw is out 1 turn on both carbs which gives me approx. 1/4" clearance between the valve and the bottom of the carb.
For what its worth, I'm using mikuni vm32's which the PO put on the bike and I know your feelings about vm32s on cb360s per reading your previous responses.  I'm planning on getting vm30's sometime soon when finances permit, but I should be able to at least get to idle with these carbs correct?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #14 on: Dec 15, 2017, 15:02:50 »
Not sure about with the Pamco, but a test light might still work? A strobe light should still work, but it might be tricky to use at starting speeds. An extra set of hands might be necessary.
Or through the spark plug hole, yes.
Offline hillset
« Reply #15 on: Dec 15, 2017, 15:08:57 »
On the Pamco website, they recommend testing the timing by attaching your strobe light to the spark plug wire and looking for alignment at the LT mark on the alternator while the bike is idling.  How can I do this without idling the bike?
Stupid question, but by ether do you mean gasoline?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #16 on: Dec 15, 2017, 15:10:46 »
It'll still spark when the bike is trying to start (but not yet idling). Same procedure, but slower flashing means it might be a bit harder to see.
Nope. Ether is much more flammable than gasoline. Often called starting fluid, it comes in an aerosol can, usually.
Offline hillset
« Reply #17 on: Dec 15, 2017, 15:14:51 »
Ok so instead of idling the bike just hold the start button in and check for alignment of the LT mark on the alternator cover while the bike is trying to start?
And I'm on the same page about the ether now, I have a can of starting fluid at home I bought for my lawnmower I'll give that a try.
Thank you so much for your help Sonreir, seriously can't tell you how helpful it is to have some guidance on these things.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #18 on: Dec 15, 2017, 15:18:26 »
Yeah. Don't run the starter for more than 10 or 15 seconds a time, though. If you can get it to work, the kick starter might be a better idea.
Offline hillset
« Reply #19 on: Dec 15, 2017, 19:00:22 »
Well Sonreir bad news...I got the timing light and the timing was way off, I believe I might have put the plate in facing the wrong direction although originally I matched the picture on the cb360ignition.com site.  Originally I had the two circuit boards of the unit facing 6 and 9 oclock, but I decided to rotate to 6 and 3 oclock.  This got me a little closer but I was still about 40 degrees off, so I decided to rotate the plate to 12 and 3 oclock.
I had taken off the e-advance and re-adjusted the Pamco plate (where the points used to sit), was in the process of tightening the bolt from the advancer to the camshaft and felt the bolt give...pulled the bolt out of the points and looked at a sheared piece of camshaft on the other end  :-\
So I guess my next step is to buy a new camshaft?  How did this break so easily?  I wasn't applying sideways pressure, and the bolt wasn't even tightened all the way when I felt it give.  I guess it doesn't really matter at this point...
Any recommendations on where to get a new camshaft?  I guess I've also bought myself a top end rebuild in the process, any advice / recommendations for taking this on?  Thanks again for your help, I'm super bummed about how this turned out.
