www.Moto-Madness.com
Author Topic: 1981 cm400t brake caliper  (Read 302 times)
Offline mada1594
« on: Jan 07, 2018, 21:40:28 »
hey guys I have a 1981 cm400t that currently has the spoke rims with drum brakes. I am looking to switch out the rims for the black comstar ones. to do this I need to buy the front brake caliper but I am looking to stay with cable brakes not hydraulic does anyone know of any that would fit? thanks!
Offline focusinprogress
  • City Limit Moto:Parts-Service-Apparel (716)8038606
    • City Limit Moto
Re: 1981 cm400t brake caliper
« Reply #1 on: Jan 08, 2018, 09:41:26 »
the only cable-actuated disc brake I know of is cb200t and I'm not sure the caliper would bolt up to a cm400t fork leg, let alone line up with the rotor on a black comstar wheel. What is making you not want to use hydraulic front brake? it can be just as clean as a cable system if you convert to a single steel braided line and use a brake switch banjo bolt to mount it to the master cyl so the wires hide with your regular hand control wiring for brake signal to the rear light.
For all your gear needs, check out CityLimitMoto.com
DTT10 code for 10% off at checkout
