'75 CB550K1 Gulf - Round...3, the fun stuff
Re: '75 CB550 unnamed - subframe
Looking good so far man. Extra gusseting is always a good idea...
Those rings look like they will probably be OK. Clean them up and examine them for pitting. Have you che4cked the size of the pistons to be sure what size they are?
Most pistons are not machined on the crown. They are cast that way and machined only where necessary.
Yep, pistons are good. They also have the factory .25/010 stamps on the crown. I might give the rings a try, but they're worse than in the pic.
I really like what you've done with the rear triangle. Nice one :)
Looks clean, man! I don't know if you really need any gusseting there, though since all that part is doing is holding up yer butt!
Actually, though, since the shocks connect there I would look at maybe some lateral gussets rather than vertical ones. It looks strong enough vertically, but you might have some sideways flex under load. I might have to get out to take a look soon. is your shop close to your house?
Re: '75 CB550 - subframe
I'm just about done with the frame, and don't really have anything else to do since I'm waiting on parts. So I decided to draw a little. I can't keep a straight line in photoshop to save my life, so I did it the old fashioned way: pen and pencil. This is my plan for the tank/seat and general stance of the bike. I might go a little shorter on the tank, and I'm still not sure how I want to shape the muffler. Hate it, like it? Opinions welcome.
Re: '75 CB550 - tank/seat ideas
Thanks Red. "Lines" are a huge thing on my mind right now. I'm trying to get every component to mesh/flow/mirror as best as possible.
Aha! So I was thinking about ways to make the tank (wire frame versus foam) and I was having a hard time justifying the headache of incorporating the petcock and front tank mounts into a fiberglass tank, not to mention shaping the tank to fit properly over the frame. It dawned on me that I could cut off the bottom/inner ridge of the tank and simply shape the new tank onto it! Think of it as using the seatpan to make a new seat, but with the tank. That way the petcock and tank mounts remain in the same place, and it fits the frame like stock. And as a bonus, the bottom of the tank follows the line exactly that I drew up in the bodywork plan. The only changes I need to make to the uh, tankpan, we'll call it, are extending it back a couple inches and forward about an inch. Man this will save me so much time.
I really like the frame work. Looks badass.
I wish I had more to contribute, but it appears you've got everything handled, and anything you don't is going to be over my head anyways. I'm good for encouragement, though. Keep it up!
Thanks IndieSol. I'm probably in over my head myself. But I guess that's the good thing about working with metal and glass; if ya screw up, just cut it off and redo!
Erskine - thanks for the link. I don't like the general shape of my tank so I'm just using the bottom for the mounting points and making the top/sides out of glass. Guess I'll be able to say I have a composite tank! hah. ;D
Man, you are going all out here. I'm gonna have to swing out to take a look at this madness. Are you around this weekend?
Yeah man, you're always welcome here. I don't have much more than a frame and a bunch of ideas right now, and my shop's ghetto as hell, but I love it! I will be in town for a few more days, through the weekend at least. Give me a ring.
Love it, man! Drive on. You clearly have "some" vision in your head...go with it.
-KR
Thanks BadKaw!
Ah, so this Friday night will be spent in the shop instead of a bar. Priorities I guess...
I didn't post any pictures of them, but the stock fork tubes were too rusted under the fork ears to be able to make pretty again, so I trashed them. I couldn't find a reasonably priced, unrusted set of cb550 tubes on ebay, so I got a set of cb650 forks. I'm using the 650 tubes in the 550 lowers, but they're a little less than an inch longer than the 550 tubes.
So, I'm shortening the forks tonight. The plan is to put a spacer under the damper rod spring (right name for it?). Anyways, it will suck the fork tube down about 1.5 inches, without having to cut the spring. I've considered cutting it, but then the tube can still extend all the way, with no pressure from the spring. I don't like the sound of that. It also provides a way to shorten the forks without sliding them through the trees, cause that's just plain ugly, no? May help provide an alternative for those considering doing that, and it's pretty damn easy. Plus, a guy could remove or shorten the spacer if need be and not affect any stock parts. The only thing you have to be aware of is not using up too much of the available compressible length. I'll post up some pics in a bit.
Don't know if I'm explaining it clearly, but you follow me?
Re: '75 CB550 - shortening forks...no, not through the trees
Here's some pics- first is the spacer under the spring. Second is the difference in fork length, about 1.5"
lookin good ringo!
your damn organized! I was that organized, but my dads a carpenter and the need to cover/uncover my work every day slowly disorganized it.
damn sawdust.
Haha, thanks man, but i should post up a full pic of the shop...not organized at all... I just move around piles of parts to keep clutter out of the pics. :D
Yeah, sawdust is a bitch. I take my chopsaw outside if I need to cut wood...
Personally I would have left the forks long.
I raised front and rear about inch and half on mine, still ground chunks off sticky out bits ;D
