ill let you in on my little secret....
strong silver base coat and our color blend gives us this!: (going on my headlight inner trim ring, tank, front fender, rear fender, fuse box, and battery box
this is my new pipe
it is a bub lakester 2-1
i am going to get rid of the rounded end of it and cut a agressive v in the back with the mill... then the shields are getting hit in white, with the tips staying chrome
(the 2-1 will allow me to get over 105hp and 115tq with my motor build after it is dyno'd)
my new 21 front wheel is getting wrapped up in a metzler 120 front tire. wheels i removed the wheel stripe in red and it is going white
front fender is getting wrapped with this custom fender
I then ordered some powder to liquid converter that when i use a 2.4mm nozel tip on my paint gun will allow me to convert the powder to a liquid paint so that i can shoot my saddle bags, trunk, and fairing all in the blue (this is all quick release)
the trunk i will glass in a 8 in sub, in the frairing 2 6x9 speakers, and in the lids on the bags a 4in round per bag, will be powered by 2 500 watt amps and a compassitor
on the mechanic side of things:
Air ride Arnett adjustable
Replace Motor mounts (front and rear) (got them just need to install)
True track
Shift light
New oil cooler lines (wrap them in black braided lines)
Tighten up sandwich plate for oil cooler
Replace tach (is slow)
Replace nutrual light sensor
Replace cam chain tensioner with newer version
Replace all 5 self sealing bolts in inner primary
Drill out damper for better flow
Replace LED’s with hyper white
Hope that it is all done mid month... just need to get the tire for the front end in and i am good to go!
