KZ400 Hardtail Bobber for sale- $1900 obob, - TN
cborders
Active Member
Finally time to sell my 1976 Kawasaki KZ400 Bobber. Built to look like its been parked in a barn for the past 30 years; however its been totally gone through and rebuild.
Run-down on build:
9k miles on original motor.
Fresh oil/ filter change
New Plugs
Valves set
Points set
1970's aftermarket pipes
Custom built single carb intake (allows easy, low maintenance)
New Keihin Flat Slide Carburetor (jetted for pipe)
New air filter
All fuel lines, filter, petcock replaced
DYNA coil with upgraded braided plug wires
New upgraded Ricks regulator /rectfier
New custom designed wiring harness with new battery, bare-bones (no signals or extra wiring)
Still runs kick and electric start
Brake caliper rebuilt
Braided Stainless Brake line
Newer late model master cylinder
Custom hardtail rear built for factory main loop (keeps stock neck, motor mounts, steering geometry)
Lowered 3 inches
Stretched 3.5 inches
Forks rebuilt- new seals, heavier weight oil, lowered.
Custom Z-Bars
Sprung Chopper style seat
New chain
New tubes and tires
Sportster Peanut tank with old-school filler
Headlight brush guard
Side-mount tail light
Tool-bag storage
I'm sure tons of stuff I'm forgetting. Bike runs great and handles amazingly well (always surprised me how well it handles)
Clean TN title in hand. $1900 obo. Bike is located just outside Knoxville TN
Contact me through forum or directly at cgborders@gmail.com
VonYinzer said:
What's the story with that intake?
Pretty common mod on the kz400 due to old rubber intake boots being near impossible/expensive to find. Also single carb makes tunning way easier, and its just something different. The original intake I built had longer runners (unequal length) but it was giving me issues with getting it running correctly. It would pool get and getting tool cold, plus one cylinder always ran too rich. This one is more compact so carb tucks into frame much nicer and has been way easier to tune.
