Re: 1972 DS7 The Long Road- monoshock conversion done
Thanks Brad. I posted the transmission spreadsheet that we talked about in the 1 800 cafe help.
I still got a cup of rust leftover from that pic if you need it.
Looking great Clem! Good to talk with you yesterday as well. Keep it up, and like I said on the phone; if you need anything for the bike, just shoot me a call.
Thanks John, I'm still tripping on your bike. It's bad dude. I really think that there are engineers in Austria at the KTM factory turning out those trick orange parts for you as we speak.
Same here Mike. I think that I remember shaking your hand now last year when I was dropping off the jerky at the tent. I booked a room today for Barber so I'll be there for sure this year but not sure what I'll be riding. I'll be looking for DTT name tags or dudes with moonshine hangovers! Haha
Alright. I got the cases buttoned up. I used the old rusty bolts for a real hipster retro look...not really, Im going to replace them slowly one at a time and put lock washers on the as per MD from PA so that the engine does bust open when it's screaming down the road. I straightend out a couple of bent fins and painted the cylinders but didnt take pics of that yet.
Well I received confirmation yesterday that the JL pipes won't fit my bike with the mono shock linkage. Bummer but at least now I won't get flogged by Von over them. I'm kind of interested in rolling my own but really don't know where to start with dimensions. Any one chime in here please. I'll be surfing the net doing research.
I started doing some reading(Gary Jennings book) and am seriously considering making my own chambers. Looking forward, I think that it may be best to set the pipes up for a stock RD350 since that is the cylinders that will go on once the funds become available. Problem is that I don't have the exhaust port timing nor the piston to exhaust flange measurement on the 350 and don't know if it is the same as the DS7 or not. It would be great if one of the fine fellows here could point me in the right direction with this. I know that I probably won't end up with a perfectly tuned pipe but I am looking at this as a chance to learn about the principles behind the two stroke. Back when I was racing motocross we would just jet, gear and buy off the shelf pipes from pro circuit or FMF. I had a guy in the Baton Rouge area that would do porting but we never made a pipe to the modified porting specs. This will probably be a slow process but I'm cool with that. I made the mistake of trying to put a timeline on the build but see now that it was a bit foolish to do so.
In addition to Gordon Jenning's book, Graham Bell's 'Performance Tuning in Theory and Practice' is well worth a read, especially regarding chambers. If you can't find a copy I can send you a pdf version.
All the porting etc. can be as good as wasted if the pipes aren't suitable.
Brad I was thinking about hitting him up to get some measurements to compare to what I came up with.
Stroker, I did find a download of Bell's book along with a free software ...2Tb I believe. I did most of the calculations based off of Bell's ranges of angles for the diffusor and baffle. The math seems to be the same between the two but it appears there is either personal or proven criteria that separate Jennings and Bell. My wife keeps telling me to just go buy a set of pipes but I think that this may be a good learning experience for me.
I put the engine in and got the clutch installed. Now I need to finish blasting the side covers so that I can polish the raised edges before they get powder coated. The wrist pin bearings that were sent with the crank were too wide for the 250 pistons so a new pair are on the way. I added mounting brackets to the seat and got a new oil tank that will fit under the seat (stolen from JohnU) so that will be a little more fab work. It's getting there.
Low to mid hit. As long as I can break 70mph I'm happy! Lol! I went with the upper end of Bell's multiplier for the header legnth. Like around 8. Thanks for the good words.
