www.Moto-Madness.com
Author Topic: Steering Stem Bearing Sizes list  (Read 66098 times)
Offline extremez31
Re: Steering Stem Bearing Sizes list
« Reply #10 on: Feb 13, 2012, 09:46:53 »
Hey guys, I'm swapping a Ninja 636 - Ninja 600 front end on a GS450. Upper's match the lower on the GS is 30x55x17 The lower on the ninja is 28x52x16.5. Can someone break down the measurements.  Any help would be appreciated.
Offline ben2go
  • Two Wheel Projectile
« Reply #11 on: Feb 13, 2012, 16:28:30 »
28 inside diameter
52 outside diameter
16.5 thickness
Offline kopcicle
  • antidisestablishmentarian
« Reply #12 on: Apr 26, 2013, 17:36:34 »
http://www.allballsracing.com/index.php/forkconversion
All Balls conversion
Quote
4. This front-end conversion search is based on bearing inner and outer dimensions ONLY! Stem length may vary from machine to machine making some combinations unworkable. As a result of front-end conversion, rake and trail may be altered, adversely affecting handling of the vehicle.
This has been helpful recently as in the past I had to do a back and forth between the All Balls catalog and K&L Supply catalog and SKS . NSK....
It was an ordeal but I got good at it .
The problem with cataloging stem lengths are many fold . Where do the upper threads start ? What clearance is there at the bottom ? Measure the frame or the stem ? Actually test the stem in the bike ?
I'm sure there are other issues to confuse but in the mean time getting the membership to include bikes in their sig line so a simple PM and a measuring tape could get you an idea would help . I'm something of a major offender here because my rolling stock (and not so rolling) changes by the week if not day .Even then I "think" I have 13-15 bikes around here .
~kop
"If a man wants to carry two cats home by their tails, by all means let him. He’ll learn things that he might not have otherwise even guessed, and the experience will be one he’ll not soon forget!"
~S. Clemens
If it leaks after all this? I'm gonna pull a "Brad" and bulldoze the fucker!
Quote from: Scruffy;1025553
As an equal opportunity bigot, I'll insult any brand, any style, any time...:wink:
-Scruffy
http://tinyurl.com/TheRedBike
Redliner: me? But I'm not a little girl any more
Nov 13, 2013, 19:20:58
Offline Hoosier Daddy
  • Earache my eye...
« Reply #13 on: Apr 26, 2013, 21:54:30 »
Very good points... take head to this.
Quote
 ;) ;D ;)
STAY CLEAN '67 BSA Spitfire
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Offline Viet
« Reply #14 on: May 14, 2013, 04:29:37 »
Great work. Thank you
Offline Ryan Stecken
« Reply #15 on: Jul 30, 2014, 14:21:25 »
Priceless
