www.Moto-Madness.com
Author Topic: turbocharged cb550 bobber  (Read 38390 times)
Online Sonreir
  • Moderator
  • Oregon
Re: turbocharged cb550 bobber
« Reply #10 on: Aug 23, 2013, 13:16:43 »
yepppp.. the roof on a vm30 carb is like 500cc or so right?
VM30 is good to around 30 horsepower.  So a single VM30 would be too small for this engine even in naturally aspirated configuration.
the way i understand it, using a turbo is like cheating on carb size since the air is being forced (sucked in this case) through by the turbine. I agree that larger would be better, but this one might work out for now.
Too small of a carb will act as a restriction on the turbo.  The restriction will take the form of a low pressure zone your turbo will have to overcome to continue to provide the correct amount of boost.  It kills efficiency.  In the case of a turbo, poor efficiency often translates to additional heat.  Additional heat means increased likelihood of detonation and/or pre-ignition.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Online Sonreir
  • Moderator
  • Oregon
« Reply #11 on: Aug 23, 2013, 13:28:31 »
Offline bradj
« Reply #12 on: Aug 23, 2013, 13:36:24 »
Ill watch kool project
Offline swansmaa
« Reply #13 on: Aug 23, 2013, 14:27:06 »
More on the topic, here, if you're interested:
http://www.dotheton.com/forum/index.php?topic=39814.msg475052#msg475052
good read, what did you end up boosting with the turbo in that picture?
Back to the carb, I was expecting a loss of efficiency from a small carb but not increased temps. my turbo inlet is right around 41mm ID before it necks down to the compressor wheel, so I would think a vm40 or so would be ideal. I do have a vm38 that I could borrow from another machine. I plan on running all stock internals on the 550 for now, so we will see how it goes.
Offline kopcicle
  • antidisestablishmentarian
« Reply #14 on: Aug 23, 2013, 14:44:30 »
Depending on your local parts sources a BS38 from a XS650 (still a little small) or a BS40 from a Suzuki Savage . Good places to start because other than having to make your main jets (get out the drills ) CV carburettors are very forgiving in a suck through ...
~kop
"If a man wants to carry two cats home by their tails, by all means let him. He’ll learn things that he might not have otherwise even guessed, and the experience will be one he’ll not soon forget!"
~S. Clemens
If it leaks after all this? I'm gonna pull a "Brad" and bulldoze the fucker!
Quote from: Scruffy;1025553
As an equal opportunity bigot, I'll insult any brand, any style, any time...:wink:
-Scruffy
http://tinyurl.com/TheRedBike
Redliner: me? But I'm not a little girl any more
Nov 13, 2013, 19:20:58
Offline swansmaa
« Reply #15 on: Aug 23, 2013, 16:57:11 »
well thats good to know, I was worried that the false vaccum created on decel in a draw through arrangement wouldnt work out well with a diaphragm carb.
Offline swansmaa
« Reply #16 on: Sep 26, 2013, 15:41:50 »
well ive made a little progress, slowly but surely. decided to build an exhaust header that was a little more direct, thats all done now. intake mani is off for powdercoating right now. Also, I just won these. 40mm flatside (Ill only be using one) So she should be able to breathe.
« Last Edit: Sep 26, 2013, 16:05:25 by swansmaa »
Offline Rich Ard
  • doin' the backstroke in an estrogen ocean
« Reply #17 on: Sep 26, 2013, 15:48:18 »
Rad. I'm in.
unplug the connectors from the harness and multimeter the shit out of them
Bad Points, a comic :: CB450 Restomod (sold) :: Viragostrosity :: GL1000 daily rider :: Kaw 175
Offline DV2000NJ
« Reply #18 on: Sep 26, 2013, 20:46:26 »
This is interesting.  I'm in as well.
Offline swansmaa
« Reply #19 on: Oct 01, 2013, 01:36:39 »
got the carbs in the mail today, and my buddy finished up powder coating the intake so i made a little progress.
new megaphone/log style header is all welded up, painted with high temp black, and wrapped in header wrap. Forgot to take pics while building it, but im happy with how it turned out.
got a buddy to machine me a steel oil galley plug with the metric male threads and an 1/8" pipe thread tapped into it. Much stronger than drilling/tapping the hollow aluminum plug. The T fitting feeds the turbo oil inlet and an oil psi gauge.
Intake is powdered high temp black and bolted up to the cylinder head.
new carb: gotta make a couple slight mods but it should work out well. 40mm flatslide mikuni, with plenty of main jets/ pilots/needles available thanks to the snowmobile world.
got a few more things to give some attention to, and i'll be pretty close to seeing if it will run.
