Ease said:
I'm guessing a few - if not all - of you have drilled your rotors at some point (or at least though about it).
3 Questions:
1. I was wondering if you had to have your rotors re-surfaced after drilling.
2. For dual disk setup, do you just clamp the 2 together, or is this too much stress on the bit?
3. Should I countersink the holes with a larger drill bit?
Also, what is the best bit to use? I have a small drill press, but I don't want to have to crack off 10 bits before I get em done.
I drilled out two xs rotors when I grafted this setup onto my Norton.
http://dotheton.com/index.php?topic=386.0
It saved a bit of weight which is good but adding a second disk adds so much weight it's allmost pointless. I went with the twin drilled disks for the symetrical appearance first, performance second. Light bikes can do well with one good disk and modern caliper.
1- I didn't resurface the rotors- I did debure the holes with a small oil stone.
2- I did each disk individually, as once both were clamped or bolted together it would be hard to lay the disk flat. Not to mention being harder to drill through with smaller starter bits.
3. Not countersinking. Just dress/debure the holes.
I used a 3d drafting program to generate the pattern I used and carefully marked the centers with a center punch. The pattern I used swept the complete pad area with the edges of the holes so the disk would wear evenly. I then drilled the holes out using steeped sizes- starting with apx 1/8 and finishing up with apx 1/4" diameters.
It was a long and tedious job. Rig up a resevoir of oil that you can control the drip rate with - little plastic dollar store clamps- guide a hose with a coathanger to the drilling area. This helps preserve your drill bits immensly.
Let me know if you want a pattern done tha you can print and use as a template.
c
