mrjoshzombie
Sonreir said:The stroke and compression numbers don't matter (as much) as the bore numbers when it comes to buy rings. I'd try to find some that are 67mm (67.5mm from Weisco is incorrect for stock size pistons on the 360). There's almost always a few sets available on eBay and they're usually listed as STD size, rather than as 67mm.
Fully noted. I need to further inspect my piston for damage when I get home and see what exactly I'm looking to replace here.
BarnBurner said:This may have been covered, but did you check the rear wheel clearance (at full compression of your shocks) before you had your buddy weld up that sheet underneath the hump of your seat? I've seen people try and do that and later have to change it because of tire contact.
Nope, it wasn't checked, but I have every intention on running a stiffer suspension if it is an issue. I matched the tail shortening spec to the same build I bought the seat from and I don't believe they had any issues. Now, my tray is welded to the bottom of the frame instead of the top, so that MAY be an issue, but I'll cross that bridge when I come to it. I don't mind a stiff ride at all.
