CB400f Cam installion
123mclaren
Hi
finishing up my top end and have a few questions. I went to put the cam in asp per the manual. Set the crank to 1-4 T mark and lined up the cam sprocket with cyl 4 lobes down and cyl 1 lobes up. Wondering if there is a possibility of this being backwards. am I over thinking this?
as long as you have it on all the marks you are good
cam to crank ratio is a 2 to 1 deal so if you think that through you can see it
Yes. All I'm wondering is does is does it matter if u have the cam flipped. Is there a zero point on the crank that's related to the cam
and be careful putting the rocker cover back on
back off the adjusters and use some rubber bands to lift the adjuster ends up
