www.Moto-Madness.com
Author Topic: Xs750 896cc engine rebuild and chop!  (Read 49315 times)
Online datadavid
Re: Xs750 896cc engine rebuild and chop!
« Reply #340 on: Nov 16, 2016, 06:00:26 »
Thanks, That was indeed.
I would not go bigger than that, for the record   also needles are shimmed 1.5mm above stock. Still have to book a dyno run to check a/f ratio, but it runs exceedingly well with this setup. After im 100% sure of the mixture i will do some top speed runs. Preferably in summer on an empty highway
Online datadavid
« Reply #341 on: Jan 17, 2017, 12:04:06 »
Did something! Bought a cheap 2" muffler and cut off the weird fishtail off the 3-1 system. This can be used to pass inspections, and ride in countries where they actually enforce sound pollution laws😀 dont look too bad either.
Online datadavid
« Reply #342 on: Jan 17, 2017, 12:04:48 »
Actually sounds real good through the rev range as well
Offline JustinLonghorn
« Reply #343 on: Jan 17, 2017, 12:14:09 »
Practical, yes. As cool, no. But I wholeheartedly understand.
Into The Sunset, CB750 build
TT500 the Animal
Online datadavid
« Reply #344 on: Jan 17, 2017, 12:20:03 »
Not cool anywhere.. wasnt the point really, would not be surprised if the sucker runs a lot better like this as well   will find out when the worlds not frozen.
« Reply #345 on: Jan 17, 2017, 12:33:01 »
I would definitely think it runs better now. Here's to the thawing of the earth.
TT500 the Animal
Online datadavid
« Reply #346 on: Jan 18, 2017, 10:20:56 »
Just gotta get new swingarm and wheel bearings in there and its good to go all season i think. Just hope the charging regulator wont give me any more problems..
I have an idea that when powering the regulator through the motogadget box, it gets a current it cannot read and regulate correctly, cant think of anything else really as all resistance checks are ok, everything is wired in correctly, brand new components - and still overcharging up to 16-17 volts as high as i dare to go rpm wise really. Think i solved it by hooking different reg and rectifier up last thing i did before parking for winter.
Online datadavid
« Reply #347 on: Jan 19, 2017, 16:37:07 »
Went out for a blast on it today, semi dry and above freezing. Not much traffic so could give it a lot of gas. Must say i like the deep muffled 3-1 exhaust note a lot better..
Online datadavid
« Reply #348 on: Feb 23, 2017, 14:45:39 »
Ha!
Offline focusinprogress
  • City Limit Moto:Parts-Service-Apparel (716)8038606
    • City Limit Moto
« Reply #349 on: Feb 23, 2017, 14:51:23 »
those handlebars make it look like the bike is having an identity crisis!
For all your gear needs, check out CityLimitMoto.com
DTT10 code for 10% off at checkout
