Evening from a cold UK.
Summer is finally over so I’ve started on my ’74 CB360 Brat build. I’ve had the bike a while now but not done a lot with it. I’ve started to strip it down in order to pull the motor and have the frame worked on. As much as I’d love to do it all myself I don’t have the skills or the tools!
Here’s a pic of how it started
And here’s a pic of where I’m at
And here’s a pic of where I’m trying to get (does anyone have any history of this bike)
My plan is to have the motor looked at and cleaned up – for the cleaning part I’m tempted to by myself a soda blaster to do the cleaning myself, can sell it after the build if need be. I will be removing the electric start. I’ll lose the stock air filters and run some pod filters.
Once the motor is out I’ll have the frame looked at, I’ve found a local fabricator to help with welding, I’m gonna go with a DCC brat seat and loop. Then it will be blasted and powder coated. I think I will also have to get the exhaust mufflers at the same time stage so I can work with the fabricator to fit them and lose any unwanted tabs from old mufflers. I’ll also need to decide on battery and location – I’m thinking of a small tray under the seat.
Once that’s done I think I will put the engine back in and install new loom with new coils, regulator / rectifier and get it running.
Stage 2 will be building out the electrics and cosmetic styling.
Questions:
Soda blasting engine casing – can I just mask up intake and exhaust when I’m blasting?
Battery – I’m going for minimal loom, kick start only, head and tail light. – any recommendations on battery that will be small enough to go under seat – something half the size as stock battery? Will this take the stock regulator / rectifier?
List of parts on list for first stage:
Start removal plug http://www.ebay.co.uk/itm/Honda-Starter-Block-Off-Plug-CB350-CL350-CB360-CL360-CB450-CL450-CB500T-MCS-013-/380888971034?pt=Motorcycles_Parts_Accessories&hash=item58aec0771a
Exhaust http://www.dimecitycycles.com/satin-black-12-inch-shorty-muffler.html
Exhaust http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-exhaust-parts-muffler-exhaust-reducer-kit-80-47310.html
Air filters http://www.common-motor.com/honda-pod-filters
Points + condenser http://www.common-motor.com/honda-ignition-rebuild
Seat http://www.dimecitycycles.com/review/product/list/id/3047/category/1722/
Tail loop http://www.dimecitycycles.com/dcc-originals-diy-custom-rear-tail-hoop-for-small-cc-motorcycles.html
Would love to know your thoughts, can it be done, plan look good, comments on parts? This is my first build and by posting regularly I’m hoping it will help me keep on track over the winter.
Thanks
Matt
Questions:
Thanks
Matt
