3/27/08
Getting back up to speed on this project; it's over the hump and starting to be in the assembly phase-
Had the inner primary welded up where id had JB-Weld before. Not that I don't trust JB-Weld...
New parts arrival this week - throttle & cable, JRC "Superior" carb, pancake air filter, exhaust headers, 6v horn & horn button, left footpeg & footpeg through-bolt w/ spacers, sludge trap & plug, a few rear sprung hub parts, rod bearings, footpg & control rubbers, primary chain & final drive chain.
Ordered a custom bearing to fit the "large main journal" new style crank and the "small aperature" old style timing side case. (Don't worry, I loctited & bolted the sump tube down before I closed the cases)
This is a fairly well-known upgrade for the old pre-unit style cranks that have no big-end bearing shells for the connecting rods; simply drop in a newer style crank and replace the timing side main bearing with the proper custom-fit bit.
New hex-head sludge trap plug, peened in place and dated.
Bottom end is almost done, just need to clean the gasket face and bolt it all up...
