www.Moto-Madness.com
Author Topic: 1981 Honda CB250rs Cafe project  (Read 7439 times)
Offline eglintonw
Re: 1981 Honda CB250rs Cafe project
« Reply #10 on: Apr 23, 2015, 04:21:22 »
Haven't checked the clearance yet! The wheels are being blasted and re painted. I'm having this sent in for powder coating next week.
I'm not sure of the size of the rear sprocket? How would I measure it? By teeth? Or diameter ?
I fairly certain its stock?
to be honest, I've never riden a motorcycle.. Or even worked on one.. This is just a project I was interested in trying! I will possibly sell it after I've finished it. All the painting is being done professionally free of charge pretty happy with it
Offline chrisbchips
« Reply #11 on: Apr 23, 2015, 05:27:24 »
Fingers crossed it clears alright!
I am just after the number of teeth, my wheel originally came with a 38t sprocket but when I ordered a new set of sprockets and chain it came with a 44t rear sprocket which I suspect is stock but wanted to be sure.
Only one way to learn! That's a great contact to have! I'm trying to find somewhere to spray my tank that won't cost a fortune. Would rather spray it myself but don't want to go spraying 2k clear in my apartment complex ;)
Offline Gumper
  • Excellence does not demand perfection.
« Reply #12 on: Apr 23, 2015, 05:37:47 »
44t rear sprocket on mine UK RSA model.  No reference in my manual?
Offline Gumper
« Reply #13 on: Apr 23, 2015, 05:52:25 »
Is that the standard battery?  As yours is the RSA kick start only model you could opt for a much smaller unit.  I'm considering a 1.2ah unit myself, it's about the size of a small chocolate bar,cheap too. 58 x 43 x 97mm 600grams. 10GBP
« Last Edit: Apr 23, 2015, 05:54:08 by Gumper »
Offline eglintonw
« Reply #14 on: Apr 23, 2015, 06:34:52 »
Could you provide any links? That would be so helpful!!
Offline Gumper
« Reply #15 on: Apr 23, 2015, 18:54:06 »
This is in the UK http://www.screwfix.com/p/sealed-lead-acid-battery-12v-1-2ah-58-x-43-x-97mm/63554
might need a resistor to reduce overcharging.  It's used in burgular alarms etc.
Offline chrisbchips
« Reply #16 on: Apr 24, 2015, 00:11:44 »
Thanks Gumper, no reference in my manual either. Pretty confident 44t must be stock.
Offline Gumper
« Reply #17 on: Apr 28, 2015, 04:50:20 »
I've just bagged a proper workshop manual from fleabay,  when it arrives I'll look to see if it confirms this, although I'm pretty sure 44t is standard.
Changing the subject somewhat.  Do any of you fellow RS owners have their front end in bits.  I'm looking into the possibility of a front end swap (due to the price of re-chroming or new stanchions) and would like some dimensions. i.e. Standard fork length, stem diameter off set and weight.  I could measure mine but I've got the backend stripped.
Offline andycafe
  • Northern Suburbs, Melbourne Victoria, Australia
« Reply #18 on: Apr 28, 2015, 07:51:48 »
Nice build buddy  ;) Bringing back some memories  :o ;D http://dotheton.com/index.php?topic=7941.0
Offline eglintonw
« Reply #19 on: Jun 05, 2015, 06:18:10 »
Finally got the tank back from repairs. Final coat goes on next week. Powdercoated frame also hopefully arrives Tuesday. So excited
