www.Moto-Madness.com
Author Topic: First build ever  (Read 15629 times)
Offline onefromexile
Re: First build ever
« Reply #60 on: Sep 18, 2016, 02:14:52 »
Jug
But he hasn't messaged back to sell yet
« Reply #61 on: Sep 23, 2016, 20:14:09 »
Who hoo just scored a set of gs850 Pistons
This baby will be a 378 now
« Reply #62 on: Sep 24, 2016, 21:49:58 »
So I'm nearly done with the head work
It's been quite the task matching the intakes to within a thousandth
The exhaust side got extensive work and the chambers and exhaust port are smooth and clean like mirrors and matched to within a thou also
I'll be going with the 378cc
Upgrade so once completed I'd like to see some solid numbers I may pay to have head flow tested
If I can find stock numbers
Im positive in a significant improvement over stock
« Reply #63 on: Sep 24, 2016, 21:56:52 »
And yes I had a hard time trying to port match intake side without taking away
As it's been researched 360's already have a great if not overkill amount of intake flow
But with the new displacement from gs850 Pistons in the plan
Any minute amount of  metal I removed from intake side cleaning up casting marks and port matching shouldn't negatively affect performance
« Reply #64 on: Sep 24, 2016, 22:00:18 »
The pictures show the left and right intake and notice the rough finish left on the intake ports I kept it a 220
« Reply #65 on: Sep 25, 2016, 17:47:54 »
chambers
« Reply #66 on: Oct 06, 2016, 21:43:51 »
New/old Pistons arrived
3 out of 4 very useable very clean
1 piston no good
And gs850 head
Which I don't need and will put up for sale  right away
Bottom line I got my set plus one extra
And two sets of wrist pins and clips
378  here we go
« Reply #67 on: Oct 06, 2016, 21:45:46 »
By very clean I meant actual metal surfaces
Have no scores or scratches
The cylinders still have honed cross hatches
« Reply #68 on: Oct 20, 2016, 01:39:52 »
Haven't been able to update much baby should be coming any day now
However I have done a lil work on the seat
« Reply #69 on: Nov 25, 2016, 15:25:23 »
In process of developing
Oil cooling system
Tcs  micro pumps
Runs about 1-7watts (controlled)
Pushes just under a liter of fluid at a constant  6psi
Should be bolt on system application except valve cover
I'll try to post a few pictures of the design drawings
It will utilize starter nose cone and end cone  thinking plexi tube in between cones inside will house micropump and controller
Lines in/out to from engine
Small oil cooler etc.
With upgraded charging system and led lighting conversion
There is enough watts to spare 1-5 for my oil system
Depending on rpms
