www.Moto-Madness.com
Author Topic: Ugly Punx XV1100  (Read 15210 times)
Offline Brodie
  • Gold Coast, Queensland
Re: "Vicious" Ugly Punx XV1100
« Reply #40 on: Nov 06, 2016, 21:26:20 »
Pulled the lower fork legs off this morning. Took me a bit to remove the lumpy rust that once was the retainer rings. Old fork seals seam ok, but I have new ones and will use them. Need to buy something to replace the retainer rings with.
Painting the fork legs at the moment. Going to rebuild the calipers tomorrow. I am working late arvo shift most of this week so I have plenty of time to get stuff done during the day. Hopefully by the end of the week I will be able to take it for a test ride.
Offline verboten1
  • Der konig
« Reply #41 on: Nov 06, 2016, 22:53:04 »
The blue spot calipers should have the same mounting, but needs an adapter at the bottom because of the leading fork, and the R6 rotors should work.
My 1000 appears to be the same setup as your bike, and the Seca wheel has the same bolt pattern, I just bolted on the R6 rotors, just not sure about spacing as my front end is apart.
« Last Edit: Nov 06, 2016, 22:55:37 by verboten1 »
1975 CB550F  Frankenbike, parting out
1982 XV920....longest owned, newest project
2000 KLR685...made it to the arctic ocean...
2001 Ninja 250...The wifes bike
2008 Ninja 250... Holy crap is this thing fun!
Offline Brodie
« Reply #42 on: Nov 09, 2016, 09:39:06 »
Brake lines are completely blocked.
A bloke from work gave me the old lines off his GSXR so hopefully they will be long enough to use.
Offline Brodie
« Reply #43 on: Nov 12, 2016, 01:01:21 »
Offline Brodie
« Reply #44 on: Nov 13, 2016, 04:22:30 »
Found a hole in the front header causing the ticking noise in the video. No idea why there is a threaded hole there but a very short bolt fixed the problem.
Just waiting on a 1m front brake line and exhaust clamp gaskets to arrive.
I also need to fab a bracket to hold the front indicators. I will bolt it where the old brake line splitter was bolted.
Offline Brodie
« Reply #45 on: Nov 16, 2016, 23:28:26 »
Just finished installing and bleeding the brakes, and wouldn't you know it I got some on the front rim. Going to have to respray a portion of it. Thinking of painting the silver parts of the tank and rear fender while I am at it.
Offline Tune-A-Fishİ
« Reply #46 on: Nov 16, 2016, 23:35:27 »
Sometimes you have to slowdown to go fast... Grasshopper  ???
Offline Brodie
« Reply #47 on: Nov 16, 2016, 23:59:18 »
Haha yep. Should have put more rags around the rim.
Offline Brodie
« Reply #48 on: Nov 17, 2016, 16:50:42 »
Just changed the fork oil and added the 10psi. I stepped up to 15w from the recommended 10w as I am 105kg and from all accounts 10w would be to soft.
Lucky for me I had a friend who had a 17mm hex key, I would have been stuffed otherwise.
Offline Brodie
« Reply #49 on: Nov 19, 2016, 17:12:13 »
Took her for a shake down ride yesterday, I need to make a bung to replace that o2 sensor on the rear pipe as it contacted with the ground. I expected that at least I know where the low point is.
Also forgot I had to wire in the front brake switch before I put the headlight back on. I will have to buy some mini blade terminals before I can wire it on.
Made a bracket out of alloy bar for the front indicators to mount to, not great looking but there will be a tool roll to mount and cover it yet.
