www.Moto-Madness.com
Author Topic: My first build - 75 Honda CL360 Scrambler  (Read 11363 times)
Offline irk miller
Re: My first build - 75 Honda CL360 Scrambler
« Reply #70 on: Jun 12, 2017, 09:11:04 »
It doesn't work as well doing a Scrambler with the cafe seat/hoop because of the clearance.  In most cases on a Scrambler, the hoop/rear of the frame angle upward and further back to give the extra length.  Here's a 70's XL250.  The fender essentially passes through the frame.
Offline djsmiles
« Reply #71 on: Jun 12, 2017, 11:42:19 »
Sonreir suggested removing the springs from the shocks which seems like a lot of work so I measured the exposed piston or whatever its called which is 2.5 inches. I removed the battery tray and measured between the wheel and the rear hoop and i have two inches. I probably lost an inch of clearance with just the tire tread compared to the bald tires that were on there. I highly doubt these shocks will ever bottom out, i can barely compress them at all with all my weight. So i'll have to change the battery tray completely. the frame is already powder coated so I can't change the rear hoop now so we'll see how it goes. thanks for all the info. live and learn.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #72 on: Jun 12, 2017, 11:48:25 »
We've all been there.
This is me, pretty much every time.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Hurco550
« Reply #73 on: Jun 12, 2017, 15:18:49 »
That's the spirit man.. really. I've seen a lot of dudes on here argue about tire clearance and not take it seriously. Good on ya for taking it for what it is, learning and fixin it! Its always a bummer to back peddle on projects, but youll have a much better machine when you do.
Bike is looking great btw
~ bradj
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
Offline djsmiles
« Reply #74 on: Jun 30, 2017, 18:55:38 »
I was having a hell of a time getting the rear brake put together today. The piece that connects to the rear wheel doesn't look like it's on all the way but it won't go any further. And where the brake pedal attaches won't go any further either and definitely doesn't look right. Any advise?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #75 on: Jun 30, 2017, 19:08:20 »
In the first pic, the brake cam might be caught on something. You'll might need to open it all up again. Make sure the splined shaft passes fully through the hub before you button it back up.
The hole on the brake lever is for the switch, not the spring. The spring should sit on the underside of the pedal. Pic attached.
Offline djsmiles
« Reply #76 on: Jun 30, 2017, 19:10:51 »
Thanks!
Offline djsmiles
« Reply #77 on: Jun 30, 2017, 19:23:05 »
I'm able to pull the cam? out and push it back in, is it supposed to be like that? And look what happened, the spring holder thing snapped off the frame.
Offline djsmiles
« Reply #78 on: Jun 30, 2017, 19:23:56 »
Pics
Offline Sonreir
  • Moderator
  • Oregon
« Reply #79 on: Jun 30, 2017, 19:27:31 »
The rear brake cam will move in and out until you have the lever bolted on. That's what holds it in place. I usually attach the lever before mounting the rear wheel specifically because of that reason. You might be able to work it on without removing the rear wheel though.
And that thing that broke is for the breather/vent hoses. The brake spring doesn't have a tab it goes into. It just rests against the frame and the lever if I remember correctly. You might have the spring on backwards?
