www.Moto-Madness.com
Author Topic: 1973 Honda CB250 Twin - Australian Build  (Read 2915 times)
Offline bvonroth
    • Instagram
Re: 1973 Honda CB250 Twin - Australian Build
« Reply #10 on: Feb 07, 2017, 04:06:32 »
I used some aluminium stock to create some small arms to tie the two gauges together and connect them to the underside of the machined triple clamp. I will stick with these for now, likely redesign in the future.
Thought i would put a few parts on and take some photos in the sun.
« Last Edit: Feb 07, 2017, 07:24:03 by bvonroth »
Offline bvonroth
    • Instagram
« Reply #11 on: Feb 07, 2017, 04:26:58 »
Welded up a quick stand to get the motor up where i could clean it, following a serious degrease and clean i then sprayed the cases. and began polishing parts
« Last Edit: Feb 07, 2017, 04:32:18 by bvonroth »
Offline bvonroth
    • Instagram
« Reply #12 on: Feb 07, 2017, 04:43:15 »
Decided rather than buying new rear shocks that i would have a go at rejuvenating the originals, removed the rust with coke and 00 steel wool, sprayed the springs with Killrust epoxy enamel and polished the struts.
Offline Green199
« Reply #13 on: Feb 07, 2017, 08:47:24 »
Shocks are looking nice and tidy, as is the motor!
Don't see many 250's around, mainly the 350's.
Keep up the good work.
« Last Edit: Feb 07, 2017, 14:05:27 by Green199 »
1973 CB250 'Doing it right this time round' - http://www.dotheton.com/forum/index.php?topic=36795.0
Offline kosmoto
« Reply #14 on: Feb 07, 2017, 13:42:47 »
Looking good! I know how much work all that polishing is.  Following along...
Offline bvonroth
    • Instagram
« Reply #15 on: Feb 15, 2017, 00:08:34 »
Cheers for the support guys!
Offline bvonroth
    • Instagram
« Reply #16 on: Feb 15, 2017, 00:12:28 »
Here is a quick vid of it running prior to tear down
Offline bvonroth
    • Instagram
« Reply #17 on: Aug 12, 2017, 04:14:27 »
Things have progressed dramatically since I last posted a long.... time ago.
Got the motor covers all fitted up with new gaskets
Decided to reduce the size of the front guard
My dad then helped me with mounting the tank and seat to the frame
Offline bvonroth
    • Instagram
« Reply #18 on: Aug 12, 2017, 04:20:45 »
Decided it was then time to take a shot at mounting the rear light, plate and indicators
« Last Edit: Aug 12, 2017, 04:47:17 by bvonroth »
Offline bvonroth
    • Instagram
« Reply #19 on: Aug 12, 2017, 04:32:31 »
Stripped the frame of all paint at his point.
Then sprayed it with black epoxy enamel.
