www.Moto-Madness.com
Author Topic: FRANKENHONDA II the 1982 DOHC CB 750F2 Build  (Read 37273 times)
Offline cb250nproject
  • If you can make it better do so
Re: FRANKENHONDA II the 1982 DOHC CB 750F2 Build
« Reply #70 on: Aug 12, 2017, 06:46:45 »
Few more runs on the board before dinner got everything in paint stripper ready for tomorrow
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
Offline Popeye SXM
  • Also used for MX
« Reply #71 on: Aug 12, 2017, 18:08:16 »
gonna have to get this project near completion over the next week
Errr  I hope you meant week(s) You are making great progress, but....... You will end up frustrated and hating the bike if you push too hard. Good luck and keep up the great work  :) I wish you both well for the big day  :-*
« Reply #72 on: Aug 12, 2017, 19:56:42 »
Lol it's true, I'm fly in fly out so I have a full 84 hrs primary focus is to get frame de tabbed, stripped and painted and engine striped and repainted then back in the frame so she's rolling again anything after that is a bonus hopefully the seat will also be finished
Paint stripper didn't work as well as I had hoped, apparently if you wrap it in foil dull side down it's more effective so I'm off to get some more stripper then back to it
Dogs are walked and fed washing done and hung out should have a full day at it
« Reply #73 on: Aug 13, 2017, 00:06:24 »
I spoke too soon apparently there is a BBQ we have to attend
First I gernied all the parts down to see what was left to get off
I'm not convinced the foil made any difference
Putting rust converter on after I hit the pieces with the wire brush
Then onto the frame
Thais is as far as I got
Online jag767
    • Kinesis Moto
« Reply #74 on: Aug 13, 2017, 04:39:12 »
Keep in mind, a little shit left on there is gonna come off when scuffed up for the paint job anyhow. What are you painting with?
« Reply #75 on: Aug 13, 2017, 04:54:55 »
Yea I'll have to give it a scuff to smooth it out after the rust converter
Unfortunately spraying isn't going to be too tech so I thought I'd use this
This is the evolution of the frame batteries for the drill are both flat waiting for it to charge so I can finish the job and get the rust converter onto it
« Reply #76 on: Aug 13, 2017, 05:47:25 »
That's where I finished up at everything in rust converter tomorrow I'll rough it up and spray then get onto the engine
Online jag767
    • Kinesis Moto
« Reply #77 on: Aug 13, 2017, 07:22:01 »
Fwiw I keep hearing good things about appliance epoxy for frames.
« Reply #78 on: Aug 13, 2017, 07:46:48 »
yea i figured if its good for roll cages it should be fairly durable. That said im still paranoid of scratching the frame when i  reinstall the engine.
Im thinking about bubble wrapping the frame when i go to in to install the engine, not sure how far ill get tomorrow as Im heading across town to my dads to have a crack at modifying the triple clamp on the mill to house the speedo and idiot lights.
If we get enough time we will try to make up some adapter plates so that the R6 rearsets can mount im thinking of using the original bolts that held the old rearsets then tap in some threads.
I  made up a wooden template for us to get the holes right
« Reply #79 on: Aug 13, 2017, 07:47:40 »
It's pretty ugly
