rs_ss350
Active Member
Joseph New York said:IMPORTANT: I entered 26mm for the offset because I measured the caliper offset was 21mm and added 5mm for width. But when I mounted the rotors, they rubbed the inner pads a little, and needed to shim the rotor mounts to center them perfectly. You could offset this by ordering the offset to 22mm or 23mm which would make the height 27mm or 28mm, and this might align better, but I think the option to shim is a luxury and if you went too offset you won't have the option. I ended up adding about 2mm in washers. But its your call. Once the axle is bushed and spaced and you get the wheel and rotors on, wheel spins good, then tighten everything up.
couple questions on your rotor design... you've got 77 for the mounting measurement. Earlier in the thread there was a 78mm measurement - did the holes line up perfectly?
