Cb750 front brake without hardline?
quadracer351
Coast to Coast
Is it okay to run the front brake without the hardline, in looking to purchase a stainless steel brake line and have it run directly into the caliper if possible. Reason being is because I swapped the brake from the front of the girl to the rear so the stock hardline won't work and I'll have to bend my own. Any help is appreciated!
Sent from my SM-G935V using Tapatalk
+1
No problem at all. If you want to keep with the threaded fitting, then you can go with 3AN brake lines. You can get them with 3AN fittings on one end and banjo on the other, or both 3AN. Otherwise, a banjo bolt and brake line for a banjo bolt is the way.
