www.Moto-Madness.com
Author Topic: Sound advice please!  (Read 4837 times)
Offline teazer
Re: Sound advice please!
« Reply #10 on: Jun 15, 2017, 17:21:36 »
We all seem to agree that checking valve (tappet) clearance is the thing to do next.  When checking them, be really sure it is done at the right point in the cycle.  It's too easy to set them when the valves are open  (right time, wrong rotation) and end up with huge clearances.
Check one cylinder at a time at TDC on the firing stroke - not at TDC with both valves open or at half stroke or any other point.
Offline quadracer351
« Reply #11 on: Jun 16, 2017, 20:39:28 »
Could not find the two sets off feeler gauges i own have to pick up another set in the morning. I took the point cover off but it looks like the matching mark on the screw is misaligned
Sent from my SM-G935V using Tapatalk
« Reply #12 on: Jun 19, 2017, 00:19:49 »
The valves all seem to be properly gapped and the cam chain tensioner tighten as described in the manual and I purchase a bore cam and everything inside the cylinder looks fine. I haven't started the bike up and had it running but turning it over by hand you can still hearing the ticking. It's very hard to tell if it's going from the cam or further down at this point.
« Last Edit: Jun 19, 2017, 01:35:08 by quadracer351 »
Offline teazer
« Reply #13 on: Jun 19, 2017, 01:42:06 »
At what point is the noise happening?  - Just before Top dead center, just after?
With the valve covers off, turn it over by hand and see if you can tell which one it's coming from.
« Reply #14 on: Jun 19, 2017, 14:02:03 »
Just spent twenty minutes trying to pin point when it happens. It sounds like it's coming from cylinder 4. Randomly I decided to cover the spark plug hole with my finger and turn it over a few times the sound wasn't there, put a plug in cylinder 4 and same thing, no tapping.
« Reply #15 on: Jun 19, 2017, 14:06:34 »
Tapping with the plug out
No tapping plug in
Online irk miller
« Reply #16 on: Jun 19, 2017, 14:32:11 »
Are the valves seated in their retainers at the top of the spring?  I'd take the tappets completely out on those two valves and look for something loose.  It still sounds like the tappets are clicking on top of the valve.
Kamn
  • Guest
« Reply #17 on: Jun 19, 2017, 15:49:38 »
I can still hear it in the second video where you say "no tapping with plug in"
It definitely sounds like its coming from valve train........take it apart.
Who put this motor together?
« Last Edit: Jun 19, 2017, 15:55:57 by Kamn »
Kamn
  • Guest
« Reply #18 on: Jun 19, 2017, 15:53:16 »
Can you get a wrench on the crank bolt (with plugs removed) and rotate slowly until click happens then roll back a little and forward on the part of the cycle its happening at.....you will be able to pinpoint better.
Also, maybe have a friend do the rotating of the motor while you have a stethoscope on it
Id also drop the oil out and inspect for any metaly bits
« Reply #19 on: Jun 19, 2017, 16:09:48 »
Works Engineering in Brooklyn. Photo of what was found during rebuild and what was done
