www.Moto-Madness.com
Author Topic: CB200 Misfiring 1 side when hot  (Read 891 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Re: CB200 Misfiring 1 side when hot
« Reply #10 on: Jul 25, 2017, 16:00:34 »
Thanks for all the responses.
I swapped the coil leads and the problem remained the same, left side misfiring once engine is at temp. I made it a little further this time before it started but I didn't let the bike idle before I took off.
The points seemed a bit burnt, so I just ran some 400 grit through to clean them up. I'll take it for a test ride momentarily.
It just feels like an electrical issue, not fuel or carbs. The carbs are CLEAN and the bike pulls through all the gears perfectly on the first straightaway. For the sake of ruling them out, if the points don't clear anything up then I will clean the carbs for a third time this afternoon and see if that helps.
Offline coyote13
« Reply #11 on: Jul 25, 2017, 16:09:03 »
Have you pulled the plug itself to ensure you're actually getting spark?  Is the plug gapped to spec?
Half the fun's in the get there...
Offline SONIC.
« Reply #12 on: Jul 25, 2017, 16:13:36 »
That would be funny.
I've had it happen before though.
In the end it's a good thing because you end up with new coils, new points, new condenser, new plug wires, and squeeky clean carbs before you realize that it's the 2 dollar spark plug  8)
Offline irk miller
« Reply #13 on: Jul 25, 2017, 16:23:17 »
Or a resistor cap going bad.  Haha
Offline Hurco550
« Reply #14 on: Jul 25, 2017, 16:53:18 »
He said in the o.p. that he replaced the cap
Sent from my SM-G900V using Tapatalk
~ bradj
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
Offline irk miller
« Reply #15 on: Jul 25, 2017, 16:55:30 »
Wasn't suggesting that it's his issue.  It was with one of mine. I was replying to SONIC's comment.  I replaced everything only to find out the resistor cap on one cylinder was bad.
Offline Hurco550
« Reply #16 on: Jul 25, 2017, 16:58:32 »
Oh haha that sucks man
~ bradj
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #17 on: Jul 25, 2017, 19:41:48 »
Took another ride after cleaning the points. Same issue. On to the next.
I may just replace the coil since they are relatively cheap and might as well rule that out for sure.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #18 on: Jul 25, 2017, 21:08:47 »
Plugs are not fouled, gaps within spec on both sides and nice blue spark on both sides. I tested compression while I had the plugs out and everything is right there, 120 psi each on a cold engine, should be sufficient.
Next step is going to be another carb cleaning. I need to order vacuum port adapters for this bike so I can put the gauge on and sync it.
Offline trek97
« Reply #19 on: Jul 25, 2017, 21:43:48 »
Yep sync the carbs   ::)
