www.Moto-Madness.com
Author Topic: Front wheel alignment?  (Read 308 times)
Offline huck_finn
    • 1974 CB360
« on: Aug 09, 2017, 23:13:03 »
I just replaced the fork seals on my 74 CB360, wasn't too bad of a job (thankfully). I was putting everything back together tonight, and noticed that my front wheel was a little out of alignment. I loosened forks a little and did my best to eyeball it.
Is there a better way to make sure I am lined up?
Offline Redbird
  • Dolor est Magister Optimus
Re: Front wheel alignment?
« Reply #1 on: Aug 10, 2017, 10:52:36 »
Got some string?
I use this method to check the alignment on my rear wheel when adjusting the chain. But it'll work on either end of the bike.
For the front, just get the bars centered and tweak the forks until the wheel lines up.
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline huck_finn
    • 1974 CB360
« Reply #2 on: Aug 10, 2017, 12:01:21 »
Thanks! How freely should my wheel rotate (by hand)? Trying to get the front pads set to the right distance from the caliper.
Offline 1fasgsxr
« Reply #3 on: Aug 10, 2017, 12:05:29 »
I usually just get things snug and do the old bicycle trick of putting the wheel between my knees and twist as needed.
I eat cake because it's some ones birthday somewhere...
Offline Redbird
« Reply #4 on: Aug 10, 2017, 12:13:32 »
It should rotate freely with just a slight drag from the brake.
