www.townmoto.com
www.Moto-Madness.com
Author Topic: Help identify these mounts  (Read 650 times)
Offline 1fasgsxr
« on: Aug 11, 2017, 22:17:25 »
Anyone know the difference between these caliper mounts?  Both came of 1973 CB 350 Fours...I was told one was from a CB 750...any help please
Offline 1fasgsxr
Re: Help identify these mounts
« Reply #1 on: Aug 12, 2017, 23:57:37 »
Bump
Online Redbird
  • Dolor est Magister Optimus
« Reply #2 on: Aug 14, 2017, 12:04:00 »
First pic on the right, second pic on the top, appears to be the CB750 brake mount.
It also appears to be a later SOHC mount. The area where the caliper clamps the mount is thinner on the early brackets.
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline 1fasgsxr
« Reply #3 on: Aug 14, 2017, 12:59:45 »
1st pic on right and 2nd pic on top are different mounts.  The thicker one is the one I believe to be a stock 350 piece.
Online Redbird
« Reply #4 on: Aug 14, 2017, 14:03:56 »
OooooooKay then :P
If it runs "1st-left, 2nd-top" are the same, then that's the CB750 mount, but it's an early 750 mount as the later mounts were thicker like the one on the right.
Which one are you needing? I can get you exact measurements on the 750 piece from my '78 750K, if you want to compare them.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #5 on: Aug 14, 2017, 14:06:49 »
The thicker one is the same as the 360. So that should be your stock mount.
74 CB360 - Luna - http://www.dotheton.com/forum/index.php?topic=63294.0
74 XL350 - The Turd - http://www.dotheton.com/forum/index.php?topic=70252.0
Offline 1fasgsxr
« Reply #6 on: Aug 14, 2017, 14:38:31 »
OooooooKay then :P
  HaHa...Im more confused than you are.  The thin one is the one that was on my 350, caliper and all. So I am hoping the caliper is a 750 piece. All I really need is the pin that goes through it, its somehow bent. I need to know too when I order pads for it..although they appear similar at 1st glance.
« Last Edit: Aug 14, 2017, 14:40:59 by 1fasgsxr »
Online Redbird
« Reply #7 on: Aug 14, 2017, 16:33:36 »
You have a 750 bracket and caliper then ;)
Pads are the same as the 350, caliper is not. If you ever need to rebuild it, order for the 750K.
Do the caliper bolts thread in from the wheel side or from the outside?
And which pin do you need?
Offline 1fasgsxr
« Reply #8 on: Aug 14, 2017, 17:54:29 »
The caliper bolts from the wheel side....I need this piece
Online Redbird
« Reply #9 on: Aug 15, 2017, 11:45:04 »
Ok, you have the correct caliper for that bracket. (they're not really interchangeable)
 I may have a spare pin. I'll check today.
