So the top end of the 650 is ready to go to the machine shop.
Need a valve job
Cylinders / pistons checked - if good just a hone on the cylinders
Everything cleaned up - bead blast cases, clean up pistons etc. Want all the black paint gone.
I'd take it straight to Concepts on Wheels as they did the work on my 550, and I ended up with perfect 150psi across all four cylinders at the end, and that was cold, freshly assembled. Broken in and warm it likely got better.
Anyhow, if there's somewhere else to go that might be more economical I'd be interested in hearing about it. Somewhere in the GTA.
Need a valve job
