Dreadnotred Hellride chopper
Looks great, nice stance and good ground clearance. Be sure to check chain interference with the oil tank.
If i did my measuring right, I should have 1.25" from the top of the chain as it passes under the tank. What I'm not sure of is how much it needs to cover the bounce. I also have 1/2" clearance to move the tank up.
pidjones said:
Will there be a rear upper motor mount?
Yes. I have to either make or get them made.
Amen frames were supposed to have them, but mine are missing:
The curse of the missing motor mount plates! Fortunately they are easy to make. Somewhere I have a pattern pulled from an OG set if you need it. At one time a couple of people were making them. Maybe White Line Creations in North Carolina! He also makes an AMEN replacement oil tank. White Line is on facebook and was a regular on the Hondachoppers.com board.
Kanticoy said:
So....
It’s still red.
I still don't have the confidence to paint it without worry of having to grind something off to weld a tab on again.
I went back and forth on trying to turn the trailer fender into something I like, but no avail. Then, I took a chance on a small fender from China listed on EBay for $30. Not bad.
looking up. I like the tail fender. If you can remember, send me the link or PM or post it in my thread on Lazarus. I need something exactly like that, pretrimmed. And its hard to buy anything on flea bay. So, if you're happy with it, It will prob work for me. thanks
