Hell, I just went to the site and found it as well. It showed up right away. I may have used some weird link to get to your site, either that or I didn't scroll down far enough. Sorry for the hassle. Either way it doesn't matter, I appreciate you giving me the info. Just an FYI for others removing the rotor, I bought a 16mm bolt with the 1.50 threads x 60mm. It might be longer than needed, but it worked fine. I simply held the rotor by hand and used an impact drill along with the correct impact socket It popped right off. Its just a Makita impact drill not a big 1/2" air impact gun. Point is it shouldn't take much to remove it. Anyone with a beat up tank with a clean inside they wouldn't mind getting rid of? Trade for some Decals? Let me know, mine isn't going to be ready in time. Trek, did you want a pic of the plug once installed? It should show up Friday. I'll throw it on and get a couple of pics. I also have to pull the head. One of the studs on the exhaust was broken when I bought the bike and Im trying to decide if welding will work on the cast aluminum or should I look for a new head.
