gijoe13844
Coast to Coast
Just picked up this beauty. 72 rd350 r5
Plan is a simple restoration.
VonYinzer said:Cool! Heads up (though I'm sure you're aware), there are several differences between the R5 and RD. Most notably in the motor (piston port vs. reed valve) but if you're doing a real resto than you'll find others. Not all things are interchangeable.
bradj said:Me!!!
bradj said:My rd has 2.15 xs650 rear hoops laced to xs650 front hubs with rd350 front spokes i also have a 120 tire up front its tight but it fits the tire is getting swaped out for a smaller something. the steering tube for a xs triple is like 2' longer than a rd/r5 and the cast lead brake calipar and rotor suck at best so toss them and grab a set off a of a fzr1000 cut the bolt circle out of your stock rotor and use it as a 1/4 spacer the big brakes will move the calipar placement to the narrowest spread ofor the spokes so all you need to do is dress the inside od the 4 pot brake calipars with a grinder and build a adapter plate and your set
clem said:Gijoe, I put up a spreadsheet on here with every transmission part and all the models that fits it
http://www.dotheton.com/forum/index.php?topic=52382.msg585726#msg585726
Let me know if you can't open it. Also I've got a ds7 seat that is in better shape than that one although not perfect.
Redbird said:Subscribed
I've got all the nitpicky stuff I took off my DS7 in a box in the shed. I'll get ya some pics, but if you need/can use any of it, you're welcome to it.
I don't have a pic right now but should be able to get one after work tomorrow.gijoe13844 said:Dude that spreadsheet is awesome. Thanks
Do you have a photo of the seat??
Sadly, I have none of thatgijoe13844 said:I am looking for a nicer rear fender, seat, and indicators.
