CB360 handlebar switch help
Butchy65
I am looking for a right CB360 handlebar switch with brake perch. I have an early 1974 with drum brakes and can't find one that has push pull throttle and a brake perch. Any help or other ideas appreciated.
If you want to delete the push cable, you could use one from a cb350k.
Otherwise search for a cl360 rh control, they had a drum also.
^What he said. They are two pieces. Also, Alzblz meant CJ360 for the drum break. I don't think CLs came with drum. Switches for the CB350s will be the same. Early 70s will be the ticket.
My original was all one piece - switch, throttle, and brake perch. I got an aftermarket throttle and used another switch. Fingers crossed
let me look in my parts bucket. I used to do a lot of 360's. Don't do them much anymore but I may have some residual parts. Where are you located?
