Re: My CM400T Cafe Build - Now a CMB400 Frankenfe
Quick update. Since I had basically finished mock up, I am in the process of tear down, going slow and documentimg/bagging parts to ease re-assembly.
Tank, seat and headlight are with painter. I have made a few changes in suspension.
The fork boots I bought on ebay turned out to be junk and are already tearing and cracking. I have always liked the look of exposed helper springs on the upper fork tubes, I found a nice set of Springs/Guides/Bushings/Boots on ebay from a '68 Suzuki T500. they are for 34mm tubes 1mm larger than the CM400's 33mm tubes. I am thinking I will run without the boots, but we will see. I do find it amazing the condition these are in considering they are 43 years old. they are in better condition than the "New" ones I bought on ebay. ...they don't make'm like they used too.
I also decided I wanted to change up the stance to a more aggressive front down, a$$ up profile. To accomplish this I am going back to the original CM400T cast alloy Upper Triple Tree that allows the fork tubes to be slid up through and lower the front. I also found a set of '81 CB750F (Super Sport) rear shocks, they are 1.75" longer than the stock CM shocks. They also have multiple dampening adjustments, that the originals don't
