neevo
Over 1,000 Posts
HUGE milestone today... I actually rode my bike on the street!
I was really pumped (pardon the pun) to get the brakes bled and see if the custom combination of master cylinder, calipers, discs and lines would actually work... let alone if I was able to bleed them properly.
I decided to bleed the master cylinder and right hand side caliper on the bike and because of the over fender line to the left, would remove this caliper to get the air out of that line. Getting the fluid to start pumping was a challenge but perserverance paid off as i was able to get most of the air bubbles out of the and side caliper within 8 minutes.
Undoing the left hand side paid off as after a few minutes pumping I started to see fluid coming through. I then attached the left caliper back on the bike to get it finally bled. Once I had the left hand side completely bled I went back to the right hand side to clear the remaining bubbles. A final check under full pressure to make sure none of the fittings leaked and it was done.
I am very impressed with the feel in the brakes, I have adjustable levers on the bike and was able to get it very comfortable and a solid feel in the lever with only about 15-20mm of lever movement.
I dropped the bike off the paddock stand and rolled it back and forth in the shed to test the brakes, all seemed good and locking the front was very easy with moderate force. The only thing that seemed not perfect were the pads, which were rubbing on the discs a bit but after a couple of runs near my house this seems to have died back as I assume the pads are bedding into the discs.
Given I now have a bike that can stop it was time to give her a test ride!!!
I grabbed the bike (minus engine) and got her outside for the first time in over 3 years:
And here is an awful video of the bike going down the hill. Excuse the wobbly video, but bear in mind there is one very happy chappy on the back!
http://youtu.be/Gt0jULYz-4A
Riding the bike down the hill also confirmed something which had been a concern for me since the beginning of the build. The USD forks and headlight mounts made the turning circle very small as the forks would hit the tank otherwise. Riding down the hill this was not a concern at all, I was able to flick the bike around with ease and had no issues at all. I will still have problems in car parks as the turning circle is so large at walking pace, but nothing a 14 point turn won't fix.
