scrambledpegs
Active Member
Alright so I picked up a little kawasaki off gumtree the other day (Aussie CL). The owner had it listed as kawasaki dirt bike, not running. So being a fan of a good bargain I borrowed the bosses ute and drove 2 hrs to pick it up.
when i got the bike home i put some new fuel in the tank and she started after 3 kicks! a bit smokey and wouldnt idle but it started. I soon realised that the clutch wouldn't engage also so I guess I was pullin the engine! I ran the Engine and frame numbers through google and I soon discovered that the frame is from a legendary G31M green streak! the 100cc 18hp flat track weapons that folks used to race before the 125 class came about. Although these things were infamous for destroying bottom ends hence the mismatch numbers. The engine is from a 1971 enduro the G4TR. These bikes had the same Rotary valve engine but detuned and with a Hi/ Low speed gear box (10 speeds!!) Luckily though the bike still had the Green Streak stinger pipe! so with a feew mods I may be able to get this thing from 10.5hp to around 18! mods include:
-Cleaning up Exhaust port as there are many casting imperfections.
-cutting the rotary disk valve to more of the G31M spec
-cutting the inlet port
-adapting a new carb, stock is a vm19 and the G31M ran a vm26
