trek97 said:Unscrew the tip off the end of the plug, it will fit in the boot.
Not sure what the "U" stands for in the denso part #. (W24ES) is specified by Honda for use in the 360.
I run the NGK B8ES. Simply cause its readily available at Advance Auto and NGK makes a good quality product.
crazypj said:The 'U' is a 'U' groove in the ground strap (side electrode) It's supposedly an 'upgrade'?
Johnnygonzoe said:Sorry for confuzing you guys. It pops but doesn't run. (NO) I didn't use the new spark plug
Johnnygonzoe said:No, it did not go back up it stayed at 12.15 volts. What I did notice with the first battery was after it drained it and i left it on it killed the battery cell. I have a feeling it's going to happen to the second one. So could it be a falty wireing on my wire harness, or regulator, or circit?
Another question gentlemen I was moving the motorcycle to check the coils and I notice my back wheel locked up as i was backing it up? I know its bad. But how bad?
