Alright guys,
We're sitting down this/next week to finalize pricing, options and a production roadmap for the hard-tails. I need to know who wants one and what model bike you have. We need to fill the highest demand bikes first..
As we mentioned previously the process will be you sending in a stripped frame for modification. We will remove the back half and graft the hard-tail to the remaining frame section via TIG welding (this would include new mid lower and rear engine mounts.) At that point it can be boxed back up and shipped out for completion on your end. This will be the least expensive method.
Additional options would be items such as:
Bow crank for linkage system
Complete linkage system
License/light plate bracket
Chain tensioner
Rear brake switch relocation tab
Electronics tube
Studs for scissor spring seat mount
Scissor springs and seat pan
Forward controls w/ new front engine mounts
Aluminum wheel spacer kit (since the tail is a bit wider than stock)
Frame mounted rear fender mount
Actual steel rear fender w/ side mounts
Sand blasting
Powder coating your color of choice
Look forward to hearing your responses and getting things going shortly!
Jason & The DCC Crew!
Chain tensioner
Electronics tube
Sand blasting
